Old 06-12-2025, 05:08 AM   #1
Unknown_Lt1
Drives: Chevrolet Camaro
Post Btr 220 cam question
Just got my Camaro back after destroying the main bearings. Currently just btr 220, rotofab cai, and DSX flex fuel. Going back for headers and msd soon. Would it be worth it to just run the lt2 I have in the garage while I wait to get the msd? Once “fbo” and cam what numbers should I be getting?
Unknown_Lt1 is offline   Reply With Quote
Old 06-12-2025, 10:47 AM   #2
7speed
Drives: 21 SS
What throttle body are you planning on running?
FBO, E85
11.1@123
7speed is offline   Reply With Quote
Old 06-12-2025, 01:25 PM   #3
Unknown_Lt1
If I put the lt2 on while I wait for the msd it would be stock throttle body. Once I get msd I will be pairing it to a 103mm tb. Sorry if I didn’t respond correctly I’m still learning how to use the forum since I joined last night haha
Old 06-12-2025, 04:57 PM   #4
GreyGhost702
Drives: 2019 Camaro 1SS1LE
The BTR220 is going to make effective power around 6500rpm. This is great for the LT2 IM. The MSD shines above 6500 RPM. You'll still make some gains over the LT2, but the cam is going to hold the MSD back, IMO. Head porting will play into this as well. I think the LT2 is going to pay better dividends with the BTR220 in terms of power under the curve over the MSD's peak performance. The BTR220 is going to run out of steam by 6700 or so.
IMO, if you're going to run the MSD you want to be running out to 7,000+.
A FBO Ported Heads, LT2 ported w/ported 95mm TB with a BTR220 on E I don't see why you couldn't lay down 500whp+ all day. E is going to help a bunch. Not sure how much E you can squeeze through the LT1 fuel system, I think around E30-40?
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
Old 06-12-2025, 05:13 PM   #5
Green82
Green82's Avatar
Drives: 2022 camaro 2SS
curious what did you do to destroy the main bearings?
Green82 is offline   Reply With Quote
Old 06-12-2025, 09:15 PM   #6
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
This right here answers your question.
Don't waste your time with the LT2 on a stock TB 87mm < 95mm < 103mm
Just wait for the MSD and 103mm otherise you are just wasting time and not gaining power.
MSD + 103 + 220 cam will shine the highest power gains outside of a high-ram setup.
But also porting the heads as Grey said will also do a lot.
Figure MSD + 103 + 220 Cam + Porting heads can increase HP by as much as 100+ with proper tuning. Just the cam and heads alone can be upwards of 90hp gain. the MSD + 103 maybe another 20-30ish.
BTR 220's are underrated compared to most cams, they can handle a supercharger upgrade if you wanted to. Obviously with a SC you'll gain more with stage 2, 3, and 4 cams, but drivability can change pretty significantly then. But if you are on a stock torque converter like I am 220 is pretty much the limit for cams, You'd have to upgrade your torque converter to go with a bigger cam.
Old 06-13-2025, 08:48 AM   #7
Unknown_Lt1
Thank you guys for the responses and info it’s very helpful and I appreciate you all. I think I’ll keep the lt2 and put it on for now and see how it feels with proper tune. Here sometime soon I’ll go ahead and pull the trigger on the msd/103mm tb and see which one I like more. The car is currently just flexfuel, btr 220, and rotofab cai. Looking to grab some headers soon when I throw the mani on. Appreciate you guys ��
Old 06-13-2025, 08:55 AM   #8
Unknown_Lt1
Bought it used 10k miles. Was told it was not abused for the beginning of its life. Later I find the previous owners social media and asked some questions and seen my car in some videos. Car was fbo since he bought it new and ran the hell out of it here in Cali doing roll races. My mechanic (master Gm mechanic) said it was either a factory defect in the crank which was unlikely, or the kid just ran the piss out of it with low oil pressure. I bought the car thinking it was stock until I had noticed he accidentally left the flexfuel sensor on it. We tried to get it through warranty but it did not pass due to the previous tune it had in the ecm files before he reverted it back to stock to trade in. Somehow it passed the stealerships certified pre owned test and was sold to me about two years ago (ignorant 19 year old kid) motor ended up blowing on me coming home from work and had to save for 6 months to get a new bottom end and a cam installed. And now btr 220 and new bottom end is how it sits now as my daily driver until I save enough to get a daily.
Old 06-13-2025, 12:49 PM   #9
DeuceCam
Drives: LT1
That sounds suspect. I bet the stealership knew it had a tune.
DeuceCam is offline   Reply With Quote
Old 06-13-2025, 04:15 PM   #10
FlukeSS
FlukeSS's Avatar
Remember Bottleneck physics.
LT2 will likely yield little to no gains until you switch to a larger than 87mm TB.
Old 06-13-2025, 05:12 PM   #11
Unknown_Lt1
I’m sure they did sadly.
Old 06-13-2025, 05:35 PM   #12
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
What year is your car? I’m wondering if this could be a failure like the L87 is having. Fluke I’m surprised you didn’t ask him this.
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is offline   Reply With Quote
Old 06-13-2025, 06:24 PM   #13
Green82
Green82's Avatar
yea i often wonder that with mine i bought a 2022 2SS with 13k miles 1 owner car. car looks good on the inside and out but never know how the last owner drove it
Old 06-13-2025, 07:15 PM   #14
m6-lt1
m6-lt1's Avatar
Drives: 2012 Shelby GT500
If your car is 2021-2024 you very likely could have had a factory defect in the crank. Google l87 recall. The L87 and LT1 have the same crank, bearings, rods and pistons
2012 Shelby GT500 with VMP Gen 3R.
Prior:
2023 Camaro 2SS 1LE
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
btr cam, cam conversion, dyno day, fbo
