![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
LT2 Intake vs MSD Intake?
I'm probably going to nuke my fuel injectors but before I do, I want to buy a new Intake Manifold. I'm unsure if I should just go LT2 or go all the way to MSD.
I notice some vendors offer LT2 in stages, like Texas Speed where stage 1 only allows you to use the stock TB and stage 2 allows you to use the ZR1 95MM TB (or any TB you want to use).. My question is, how much work needs to be done to a LT2 intake in order for it to work in my SS and run a larger TB and more importantly, is it worth it or should I just go MSD? |
![]() ![]() Drives: 2017 2ss 6mt Join Date: Mar 2024
The big question is how much gain per dollar is either one of them?
$1500 for 7hp? |
![]() Drives: 2023 2SS 1LE Join Date: Dec 2018
It gives other mods the air volume to peak.
Sent from my iPhone using Tapatalk |
Here is a thread I found in less than 1 minute of searching. https://www.camaro6.com/forums/showthread.php?t=592275
#5 | |
![]() Drives: 2019 Camaro 1SS1LE Join Date: Jan 2024
Induction parts, more than anything, are harmonious with the overall build combo. For example, you don't get the full benefit of a MSD without a head/cam combo that makes power out to at least 7k/rpm+. More so, you don't get much out of an intake manifold upgrade at all without a head/cam combo that flows. You can make gains just bolting on parts, but you leave untapped potential if you don't put the right parts together. As far as untapped potential, there is bits to be had in porting out intakes and throttle bodies. The more air the car is capable of flowing, the more potential there is in a ported part. Porting won't always yield the same gains. For example, if Texas Speed claims +15whp in a ported part over non-ported, you'd have to run their exact combo mule car to see it, and the stars/dyno gods align as well. When we're talking NA combo's, there is a balance between air velocity and air volume. FI plays by somewhat different rules. Once again, it comes down to what is your overall power goal for the car, and build combo. That is what should determine your parts list. I will say, when done right the LT2 is hands down the best bang for your buck. It's not as big of a monster as a MSD or Hi Ram, you won't see it on max effort builds. But it is the king of 500whp+ budget builds, IMO.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane 7/26/2024 Tuning in progress |
![]() Drives: 2022 Vivid Orange LT1-M6 Join Date: Dec 2015
In my opinion, find a used ported MSD from someone and make sure it was ported by Pray, Mamo, or someone who has proven porting experience.
https://www.camaro6.com/forums/showthread.php?t=587847
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph |
#7 |
![]() Drives: 23 2SS 1LE Join Date: Feb 2019
I did the stage 3 ported LT2. Came out cheaper than the MSD and has all the same low end power and the top end is only a few horsepower short. From all the research ive done, the LT2 is the best bang for your buck, and the MSD really only shines if you have a cam and want more top end power.
To make the LT2 fit, you just need to shave the bottom and a hose and harness extender. They sell kits for this if you want to do it yourself. To fit a larger throttle body, you just want to port the snout, but if youve never done this before its best to have a professional do it.
Instagram: RideWithDanger
Current Mods: Rotofab, Ported LT2 intake, LT5 TB, Kooks Headers, AWE Touring Catback Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 |
#8 | |
this one is probably the best all around comparison video |
#9 |
#10 |
You are learning well grasshoppa.
#11 |
![]() Drives: 1999 Z28, 2011 2SS VERT, 2016 1SS Join Date: Mar 2018
The Lt2 is absolutely the best bang for the buck. They claim 20 rwhp from just bolting it on a stock car with no tune so I tested that. I put my 2016 1ss on the Dyno and swapped the intake on the Dyno after making some pulls . Kept them engine temp and everything the same. I made exactly 20 more rwhp. The only downside to using an Lt2 intake is if you have to upgrade to an Lt4 hpfp is the Lt2 will not clear the pump. I didn't know this so I ended up buying an msd I found a deal on. If not for that my car would still have an Lt2 on it.
Just to be clear I did the comparison with both intakes stock , not ported and it was a 20 rwhp gain with no tuning. I have a Dyno jet 248 just like Pray used in the video.
2016 Camaro 1SS, A8, rebuilt engine with GPI forged drop ins, Cam Motion stage 2 Pd blower cam, C5R chain, LMR chain tensioner, Katech pump, MSD intake, 95mm tb, I ported my heads, speed engineering 1 7/8 long tubes hooked to the factory exhaust , Lt4 fuel system. 505 rwhp, 461.8 torque
#12 | |
#13 |
I almost want to run an lt2 intake just for the cover that goes on top.
#14 | |||
