![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
SS LT1 Fuel Injector Questions
2017 2SS
It appears there are several different part numbers for our fuel injectors even for similar models and years (Even the SS from a 2017 has multiple different PN's vs a SS and ZL1) It seems like the only reliable way to get the correct injector is removing the old one and examining the PN from it. Questions: 1. Why did GM do this? 2. Are the PN's interchangable between similar years and models or is it absolutely necessary to get the correct PN? 3. How much power do stock injectors support? 4. Can they support F.I.? 5. Are aftermarket injectors available for our cars and when do you start looking into them? 6. Do after market injectors support our cold start duty cycle? (dumps a ton a fuel and very loud cold start) |
![]() ![]() Drives: 2017 2ss 6mt Join Date: Mar 2024
1: GM will build a car using the cheapest parts that will do what needs to be done. That's where engineers and bean counters have conflicts.
2: part numbers change for lots of reasons, some being they found cheaper ones that do the same thing. Some being changes were needed. 3:enough 4:yes 5:yes, when your stock ones cant keep up 6:injectors don't have an affect on cold start cycles. A fuel injector is a solenoid that acts as a controllable gate. When it is commaned open it lets fuel pass, when the command stops fuel flow stops. It has a specified flow rate that changes depending on how far it opens, the holes that fuel comes out of, the path the fuel flows in. Your injection cycle is a duty cycle control setup. Each time its needed the computer will send a series of on commands within a specific time frame. Its a pulse width modulated signal. So for example you have 500psi in the rail and you commanded an injector on for one second at a 50 percent duty cycle. Then it will be on and off 50 percent of that second. And flow fuel related to that time/duty cycle. If you needed more fuel that what the rate allows, you increase the on time(which is how long the gate is open). Change it to 60 percent duty cycle and it is open longer letting more fuel to pass. Eventually you will come to a road where no matter how much you leave it open you can't get enough fuel to feed the need for the engine. Thats when you need a bigger gate that flows more fuel per second. (Bigger injectors) So now you have bigger injectors, the duty cycle that you had before doesn't match anymore. 50 percent duty cycle will dump much more fuel than it did before. So now you have to go retune just to get the car to run normal. |
Reason Im asking is because my stock injectors keep failing and leaving me with random misfires. I replace and it works for awhile then another one fails. I was wondering if going aftermarket would be a better idea than going back with stock injectors.
Currently Im at about 500 RWHP and running E85. So far Ive replaced: Injector #4 (about a year and a half ago) Injector #5 & 6 together and it worked for awhile Now both 5 & 6 need to be replaced again so Im thinking of just nuking them. |
#4 | |
Moderator
Try running 93 more often. It lubricates better.
#7 |
Moderator
It’s easy to do when you put the blower on, since you have to take the intake manifold off to do the Whipple or Maggie anyway. If you’re going to do a centrifugal blower then I suppose you could do the injectors anytime. But yeah, do them now if you want. You’ll just need your tune adjusted when you do since the LT4 stuff runs at higher pressure and has different flow rates vs LT1.
#8 |
Moderator
93 is trash on a high compression boosted motor FYI
#9 | |
I have a magnacharged 99 Z28 but I wonder if I should do the same to my SS or if Im ganna keep my SS NA. |
#10 |
Crapped out injectors from lack of lubrication is pretty trash too. But i guess i don't really care if I'm ready for the next light to light street race. I go more for the make it back home with no problems.
#11 | |
Moderator
So, give me boost everyday of the week. ![]() I’ve been E85 since 2019 with no injector issues FWIW. But nothing wrong with reliability so I understand where you’re coming from. But if you want to play in the boosted world, E is where it’s at.
#12 |
![]() Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
A few oz of Marvels mystery oil will keep the injectors and fuel pump lubed 4oz per tank of E85 dose the trick.
DARK KNIGHT
2018 SS A8 11.37 @ 121.01 GPI Tuned E85 Nitto tires Roto Fab CAI MSD intake |
#13 |
I don't think its the E85. I've been running it for about 3 years now but these misfires just started and gradually progressed a few months ago. Originally it only happened during that loud cold start period but ran normally after warming up so I ignored it, but it's gotten worse. I replaced the injectors with some used injectors lying around at the shop I use to test it, and it got worse instead of better.
I'm going to grab new injectors and see what happens. |
