![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I broke her
Hydroplaned getting on the highway, knew it was a thing, it was raining and on my mind, was taking it easy but not easy enough. Felt it wiggle then the rear violently broke loose and fishtailed me off the pavement at about 50mph through the grass and down a minor embankment. Right front hit hard before it came to a stop. No air bags n no injury’s for me.
![]() Drives: blue velvet Join Date: Jul 2018
Ouch dude. Glad you're ok.
![]() ![]() ![]() ![]() ![]() Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
Glad no injuries for you. Our Camaros have some of the best crash ratings. The car can be repaired.
![]() Drives: 1987 IROC, 2020 ZL1 Join Date: Nov 2023
Ooh damn, sorry man! But glad no injuries. Just out of curiosity what kind of tires are you running? Also as stated above totally looks repairable.
SC3s and all nannies were on.
Thank you Al Oppenheiser!
Sorry for your loss.
GYF1SC3s will indeed try to kill you in rain. Glad you're OK! |
#7 |
I'm very sorry to see your beauty in this rough shape, but it's a blessing you weren't injured.
This is the main reason why I have PS4S tires on the car, by the way. The runflat Goodyears that came with it were about as bad in the rain as your SC3s.
#8 |
![]() Drives: Camaro SS 1LE M6 Join Date: Feb 2024
Glad you're ok, this is what insurance is for, hopefully they cover most of the repairs.
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold |
#9 |
2020 Shadow Gray 2SS
Sucks that happened to you, but very glad to hear you are ok... The airbags not going off make this a very repairable situation, find a really good body shop...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (475 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#10 |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
Glad no one was hurt, that sucks bro! Did you have traction control enabled? I hope things work out!
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#11 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
#12 |
Bro, I responded to his first post! I dream of the DAY, I am even close to being a perfect as you !!! I promise I will keep striving for your level of perfection!!
#13 |
$11579.00, less my 1K deductible
Labor $3675 Parts $6876 Materials $1028 The itemized bill is 98% superficial body and glass stuff. Mechanicals: Trans Oil Cooler (remove/replace) Air Bag Sensor (remove/replace) Engine Wiring Harness (Repair; says: Splice) R Cooling Aux Radiator (remove/replace) |
#14 |
Petro-sexual
Yeah - that damage isn't bad. It's probably a "good" thing it happened in the rain, because of how much it slid over stuff.
Glad you're okay though.
