Old 06-07-2025, 09:46 PM   #1
AZIROC
Drives: '86 IROC-Z '18 ZL1
got new windshield installed..now I see the headliner?
So after a few rock chips and a crack I decided to to get the windshield replaced. Used a quality company / glass (not safelife) and the installed told me even before Installing the glass that he sees it alot on 6th gens. I already had a small area on my psg side from the factory but now its pretty much my whole psg side is visible.
Is there any to fix this? I did a search and people kept linking a product on Amazon, but when I clicked on it it came back "items not found."
Old 06-07-2025, 09:51 PM   #2
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Do you have a photo of what it looks like now?
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 06-07-2025, 10:01 PM   #3
AZIROC
Not on my but I can get 1 later its just down enough to where you can barely make out the "yellow" of the headliner . Driver side isnt nearly as bad
Old 06-08-2025, 07:47 AM   #4
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
I just got a new windshield from Glass America. Everything turned out very well for me, top notch service and the aftermarket glass is just fine. They told me that its OEM glass without a logo. Anyway, I don't see the head liner at all.
My Camaro Journal
Old 06-08-2025, 06:35 PM   #5
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Here's a TSB issued to dealers re: sagging/exposed headliners. Hopefully you can make some use of it.
https://static.nhtsa.gov/odi/tsbs/20...55053-9999.pdf
