Old 06-07-2025, 12:07 AM   #1
tatsandcats
Drives: 23 camaro 2ss
Brake pads 2023 camaro 2ss (non 1le) help
Can someone point me in the right direction on the part number for the stock oem brembo pads front and rear for the camaro 2ss? I have the regular 4 piston front.
Not sure where to buy at. Pads need changed at 21k miles already, geesh.
Dealership wants to charge me 1k for just the front pads and rotors. Not sure I need rotors with only 21k miles
Any recommended places to purchase? thanks!
tatsandcats is offline   Reply With Quote
Old 06-07-2025, 01:01 AM   #2
SpeZ
SpeZ's Avatar
Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30
Front rotor: 13528522
Rear rotor: 85589611
Front pad kit: 84732488
Rear pad kit: 84732503
I buy my stuff usually at rockauto.
Front rotor has a minimum thickness of 1.06 inch.
Callaway SC750 ZL1, DIY 1LE with added OEM 1LE Wheels, DSSV Suspension and 1LE Aero, FEA front control arms, DIY oil cooler, CWA 150 pump, bigger intercooler, BMR lockout kit, CTSV Brake Air Deflectors, Smooth idle cam, LS7 lifters, CHE trunnion bushings. Tuned by JRE
SpeZ is offline   Reply With Quote
Old 06-07-2025, 01:27 AM   #3
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
https://www.camaro6.com/forums/showp...91&postcount=2
Do you want the Brembo Pads (if you track the car) or do you want the much lower dust (and longer lasting) PowerStop Z26 Pads (if you only street drive the car)? https://www.amazon.com/Power-Z26-147.../dp/B00Z6LM73G
Those are the fronts, here are the rears... https://www.amazon.com/dp/B00Z6LMNBW
Old 06-07-2025, 02:36 AM   #4
tatsandcats
Thank you so much for the quick reply man, im highly considering the powerstop pads, i don't track but do enjoy spirited drives, how would you compare them to the brembo pads? Will only stop quick in an emergency, are they pretty comparable?
Old 06-07-2025, 02:37 AM   #5
tatsandcats
thanks for the reply man, i'm still considering whether to go with brembos or the powerstop pads. I love this community. beautiful zl1 btw, i bet she rides great.
Old 06-07-2025, 08:26 AM   #6
Ray3768
Ray3768's Avatar
Drives: 1977 Trans Am, 2024 Camaro 2SS
Back when I had my 5th gen SS and it needed it's first brake job I decided to go aftermarket with a set of R1 Concepts drilled/slotted rotors and their "factory compound" pads. Upon unboxing the new parts I saw that the brake pad material was a beige color. These were a ceramic pad, not factory semi-metallic. I was a bit disappointed but I went ahead with the installation. While they didn't dust the wheels as much, initial bite was significantly less and I had to press harder on the brake pedal to get the same amount of stopping force. Keep in mind that this was a street driven car, never tracked and I could still notice the reduction in performance. The pads made it to 50% wear and the brake pedal was pulsating. I tried to whiz-wheel the front rotors and re-bed the pads. Felt better for about a week then the pulsations came back.
At that point I was done with them and replaced all four corners with factory pads/rotors. The car felt brand new again.
Go with the Brembo pads. Let the wheels turn black from brake dust. You can clean the wheels and they will be fine. At least your car will stop properly.
-Ray
Ray3768 is offline   Reply With Quote
Old 06-08-2025, 09:15 AM   #7
ctrlz
I have 2017 2SS as my daily driver (not tracked) and I put about 5000 mi/yr on the car.
I much prefer the powerstop pads. Braking performance feels equivalent to me. I had no noise with either the stock semi-metallics or the powerstop ceramics.
I changed the fronts in 2019, which was easy.
Did the rears in 2024 and all 4 rear pads were cemented in the calipers by brake dust, meaning they were not freely movable as intended. The brake dust created by semi-metallic pads is higher in iron content, and basically stickier when it interacts with moisture. That's why you need acid-based products to clean it off your wheels.
I live in coastal New Jersey. If you are in coastal FL it will probably be the same.
Now if you burn through your brakes every two years, it won't matter. I typically get about 80,000 miles out of rear brakes.
Old 06-16-2025, 11:00 AM   #8
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2020 2SS
Z26 for the win, but reuse your factory clips and hardware. I love not having to scrub my calipers and wheels constantly. Stopping is just fine for street use.
Bad Anvil Garage is offline   Reply With Quote
