Old 06-04-2025, 08:29 AM   #1
James Montigny
James Montigny's Avatar
Drives: 2017 Camaro 2SS
James Montigny
2017 Camaro 2SS A8 - Krypton Green
Magnuson 2650 @ 13psi, Forged TSP Rods/Pistons, TSP Ported Heads, BTR PD Cam, Aeromotive Low Side, DSX Flex, LT4 HPFP, 103mm TB, Big Gulp, Meth.
Built by Killer Performance, Tuned by Justune.
James Montigny is offline   Reply With Quote
Old 06-05-2025, 12:06 PM   #2
Darkfuzion
Drives: Camaro SS 1LE
I would assume those are BTR .660's, they are the most common. They could also be PAC Racing .660's. Also, I think those might be titanium retainers.
Darkfuzion is offline   Reply With Quote
Old 06-05-2025, 06:30 PM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by James Montigny View Post
The important part is that they'll hold up at 7200rpm under 20+ lbs of boost.
You might want to have them checked or just get a new set. Keep in mind you lose some spring pressure due to boost in the cylinder. You are kind of rolling the dice…you don’t know if those springs were ever floated previously and it’s kind of a disaster if things go sideways at 7200 RPM…
Old 06-06-2025, 07:35 AM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I don't think I would run used springs on a new build.
Old 06-06-2025, 07:36 AM   #5
James Montigny
You put used springs on a new engine?
Bought the heads assembled from TSP.
All brand new at the time.
James Montigny
Old 06-06-2025, 07:39 AM   #6
Joshinator99
Moderator
Sorry, the original post made it sound like they were used when you bought them, so that’s why King and I responded the way we did.
So that being said, you could have a quick conversation with TSP about those valve springs still being good for your setup at 7200 RPM and with 20# of boost, since they’ll also know the weight of the valves they sold you.
