Old 06-02-2025, 11:29 AM   #1
LtColumbo
LtColumbo's Avatar
Drives: 2017 1LT RS V6 A8, 2020 Fusion
Where Did It Go?
I bought a Range AFM several years ago. I remember before installing it, there was an indicator on the dash that showed "V4" or "V6" depending on the driving conditions.
It's time for the first "smog test" and I need to remove the device so they can do the test. I wasn't sure if, after removing the device, I would have to drive the car a certain number of miles/cycles to set the ECU for diagnostics. I know if you replace the battery, you cannot immediately do a smog test. I called Range and they said, "NO, just unplug the AFM and drive it to the test station."
I unplugged the AFM and drove around for a bit, but I'm just now noticing there is no V4/V6 indicator on the dash! I have not driven much, so I'm not sure if it is switching between the 2 now.
Where did the indicator go? What am I missing?
Thanks!!
LtColumbo is offline   Reply With Quote
Old 06-02-2025, 11:39 AM   #2
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Thanks!!
Look on the Fuel Economy screen...
Old 06-02-2025, 03:20 PM   #3
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
The Range AFM would be an on/off situation. If you have it plugged in, AFM is off. As soon as you unplug it, AFM is on. It doesn't need to run through any cycles or anything to turn on/off. As Capt said, flip to the Fuel Economy screen to see the indicator. Otherwise, it doesn't show up.
My Camaro Journal
Old 06-02-2025, 04:24 PM   #4
LtColumbo
LtColumbo's Avatar
YES! (Of course!) It's been so long since I looked for it, I forgot that it isn't always visible. It's not specifically mentioned in the Owner Manual that I could find.
THANKS!
