Old 05-31-2025, 04:56 PM   #1
Steve65
Drives: 2013
Check engine light
Check engine came on my 2000. The code is P0014. " B" Camshaft position. Timing Over Advanced performance bank 1. Any help would be appreciated....after did scan the light went off
Steve65 is offline   Reply With Quote
Old 05-31-2025, 06:39 PM   #2
RIPws6
RIPws6's Avatar
Drives: 2019 2SS Riverside Blue
It was most likely a faulty sensor reading. Some code readers automatically clear the codes out when using them.
Fingers crossed it doesn’t come back.
RIPws6 is offline   Reply With Quote
Old 05-31-2025, 11:58 PM   #3
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
i see that code all the time on 4cyl and 6cyl gm engines. usually a result of the customers running out of oil, then realizing they have ran out of oil, go add oil and the light remains.
the cam phasers usually take a lot of damage from no oil to cushion the internal parts from each other.
look at your camshaft commanded verses actual degrees. unless you dont have a scan tool. then just buy the chain, guides, phasers and replace them all. and keep track of your oil better.
bishopts is online now   Reply With Quote
Old 06-01-2025, 12:32 AM   #4
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
W. T. ABSOLUTE F.???
Old 06-01-2025, 08:17 AM   #5
bishopts
bishopts's Avatar
Im a diag tech as a career. 24 years now. I see it ALL the time.
Old 06-01-2025, 10:56 AM   #6
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
Hopefully it is just his non-Camaro customers that are running out of oil!
Old 06-01-2025, 11:22 AM   #7
bishopts
bishopts's Avatar
Mostly CTS people. For the 3.6, which is the 5th gen camaro engine but the 6th gen 3.6 really isn't much different. I do have hopes they aren't as problematic with oil consumption.
Regal and equinox people on the 4 cyl. Which isn't on the camaro platform. The gen 3 ecotec went to low tension rings and after that the engine struggled with oil consumption. They are durable as hell. Ive had too many to count drive in with engine clatter and cam codes. Add 4 quarts of oil and the clatter dies down some but the guides will be destroyed and the chain is streached.
One of the most impressive ones I've seen was a traverse that DROVE in, it had high pressure fuel codes. Bank 2 chain was gone so the cams on bank 2 weren't turning and the high pressure fuel pump wasn't being driven.
Old 06-01-2025, 05:47 PM   #8
p47dman
Drives: 2024 Camaro 1SS
Glad I live in MN.
p47dman is online now   Reply With Quote
