Old 05-30-2025, 10:01 PM   #1
Ruby13
Ruby13's Avatar
Drives: 2019 2SS/1LE Shadow Grey
PTM Modes Selection
Does anyone have info regarding getting to PTM modes more easily? Yeah everything is track mode and then 2 times on tc about a second apart but I have to try the double tap on the traction control button 20+ times before the secondary PTM modes menu pops up, it always just turns off tc and or stabilitrak takes forever for PTM modes.
Ruby13 is offline   Reply With Quote
Old 05-31-2025, 06:25 AM   #2
cdb95z28
cdb95z28's Avatar
https://www.camaro6.com/forums/showthread.php?t=496996
"KEEP THE FAITH"-Fbodfather
Old 05-31-2025, 06:39 AM   #3
SpeZ
SpeZ's Avatar
Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30
If the ptm mode menu doesn't show up right away, no worries.
When you hit the driving mode selector, the ptm mode menu appears.
Callaway SC750 ZL1, DIY 1LE with added OEM 1LE Wheels, DSSV Suspension and 1LE Aero, FEA front control arms, DIY oil cooler, CWA 150 pump, bigger intercooler, BMR lockout kit, CTSV Brake Air Deflectors, Smooth idle cam, LS7 lifters, CHE trunnion bushings. Tuned by JRE
SpeZ is online now   Reply With Quote
Old 05-31-2025, 12:34 PM   #4
Ruby13
Ruby13's Avatar
even after hitting the mode selector the modes don't come up for the secondary menu, seem's to take alot of attempts. Just must be a quirky typical chevy issue
Old 05-31-2025, 10:55 PM   #5
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
I've found that the timing of the 2nd press relative to the 1st press is what seems to be critical in bringing up the PTM menu; not that I get it right every time, LOL.
Start at one end the spectrum (2 times with extremely short interval between presses), and if it doesn't work, pause a few seconds and try again, this time with a slightly longer interval. Repeat with longer and longer interval between presses until it works. Congratulations, you found the interval between presses that is needed!
N Camarolina is offline   Reply With Quote
Old 06-01-2025, 03:47 PM   #6
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
I tried it out, but didn't have any issue getting in?
2016 1LT v6
- Totaled
Happiness: Infinite
Bumbleboy92 is online now   Reply With Quote
Old 06-02-2025, 10:01 AM   #7
Ruby13
Ruby13's Avatar
yeah, mine doesn't usually work so I have do it it multiple times, my guess is each car might be a tad bit different in timing.
Old 06-02-2025, 02:53 PM   #8
KirillWA
KirillWA's Avatar
Drives: 2022 Camaro 1SS 1LE
Also make sure that cruise control is turned off (no cruise control icon on the dash). It will prevent PTM from activating.
In my case timing of pressing it has pretty broad margin, so never had an issue there.
2022 Camaro 1SS 1LE Rapid Blue 6MT
Looking for traction on wet pavement in Seattle.
KirillWA is offline   Reply With Quote
