Old 05-30-2025, 06:22 PM   #1
IceGoaliePaul
Drives: 2018 Chevrolet Camaro 2LT
Air filter screws
I had an oil change place loose two of the screws from the air filter housing. Just letting people know that the GM part number for the exact replacement is 13384934 for a 2018 LGX and I assume all of the other years. None of the parts places list the screw part number separately only the entire air filter housing assembly.
IceGoaliePaul is offline   Reply With Quote
Old 11-26-2025, 12:29 PM   #2
Rob99
I’m Magik a physco dog
Rob99's Avatar
Drives: '15 1LT/RS & '23 3LT/RS
I noticed they use the screws instead of clips when i changed out my filter and i can see its easy to drop them, thanks for the part #.
2023 3LT RS Shadow Gray
2015 1LT R/S Blue Velvet Coupe.
Previous:
2015 1LT Ashen Grey
2016 1LT Blue Velvet
My entire life has been 'A Midlife Crisis'
Rob99 is offline   Reply With Quote
Old 11-26-2025, 08:12 PM   #3
lowke
lowke's Avatar
Drives: 21 Camaro V6 manual
The phillips head sucks. Keeps me from checking it as often as I would if it was hex head. I would like to find hex head screws that would work. The air filter is the same part for 4,6 and 8 cylinder, so I imagine same air box. I have read the inlet to the air box the weak point for air flow.
lowke is offline   Reply With Quote
Old 11-26-2025, 09:07 PM   #4
Rob99
Rob99's Avatar
Agreed they were on very tight and eventually after a certain amount of remove / install I'm guessing the plastic screw holes could strip out.
Previous:
2015 1LT Ashen Grey
Old 11-26-2025, 10:38 PM   #5
lowke
lowke's Avatar
It doesn't feel like the plastic will wear or strip out .The Phillies head screws are hard to keep a grip on. A ratchet screwdriver makes it easier. If the plastic striped out I would put Teflon tape on the screw threads.
Old 12-11-2025, 07:05 AM   #6
Mid_Life_Crisis
Mid_Life_Crisis's Avatar
Drives: 2023 Chevy Camaro 2LT V6 6MT
Really stupid of GM to not just use clips. Why complicate things?
2023 Camaro 2LT V6 6MT Vivid Orange Metallic
Mid_Life_Crisis is offline   Reply With Quote
