Old 05-26-2025, 08:30 PM   #1
Jaspa57
Drives: 98 Trans AM
Car turned off and back on while driving
Was out for a ride today in my 2020 ZL1 M6 convertible. While driving the car turned itself off then back on by itself within a few seconds (that's what appeared to happen). Instrument cluster went blank, car bogged, no throttle response, then instrument display came back on and now had throttle response, but no sound from the stereo. I had rev match on and TCS off. Now rev match was off and TCS was back on. I was able to change them back to on and off, but had to stop and turn car off/on to get the stereo sound back. This happened twice today. There is a recall for the BCM that has not been done yet, related or not??? Anyone else have this issue?
Jaspa57 is offline   Reply With Quote
Old 05-27-2025, 06:26 AM   #2
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
So, were you moving when it came back on, if the car died, at it was moving in gear that could be what restarted it (like a bump start). Look for loose -NEG battery terminal connection? I don't think that problem is related to the recall. I've not seen that issue posted before. Maybe get your battery tested? When these cars have battery issues they do the weirdest things. I had to replace my battery, prior that same day. I couldn't leave a car show, it would start, rev'd on it's own, dash lights went nuts, warning messages on dash etc. I was able to start the car, but it ran bad at first, I had to keep turning it off and restarting (4 times) until enough cleared up to where I was able to drive it home. Then took the battery to AutoZone and they said it had died. It was so dead it wouldn't test, they tried charging it and it wouldn't take a charge. Good luck.
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 05-27-2025, 11:16 AM   #3
Z OH 6
Drives: 2024 CT5-V Blackwing
That's a gas savings feature.
Old 05-27-2025, 11:59 AM   #4
ZL14ever
Drives: 2018 Camaro ZL1 A10
Something similar happened to me last year when I broke the alternator belt. Car turned off for few seconds & then turned back on by itself
ZL14ever is offline   Reply With Quote
Old 05-27-2025, 02:05 PM   #5
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Maybe it’s just a bad battery, alternator or belt hopefully? I know these cars are very finicky with voltage drops.
pauly1119 is offline   Reply With Quote
Old 05-27-2025, 06:06 PM   #6
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Check for:
1. water in the trunk
2. hairline cracks in the bus bar and fuses in the battery top positive fuse block.
Old 05-28-2025, 08:29 PM   #7
Jaspa57
Drives: 98 Trans AM
Problem found. Had time today to get into rear battery compartment. The positive terminal connection was loose. Just touching it the battery disconnected. I must of over torqued the connection and damaged the clamping mechanism putting the battery back in a couple of weeks ago after the Winter nap. I cannot get the connection tight even using a shim. The nut gets nice and tight, but the clamp will not tighten to the post. Will need to replace the positive terminal fuse block part# 84081785.
Old 05-28-2025, 08:37 PM   #8
Thanks for reporting back and giving us a new data point Glad you found the culprit.
The part number comes up as a rear body fuse block, not a terminal clamp, are you sure this is the one that got damaged?
Old 05-28-2025, 08:48 PM   #9
Jaspa57
Drives: 98 Trans AM
Yes, clamp is part of the fuse block terminal.
Old 05-29-2025, 06:34 AM   #10
2023_ZL1-AUTO
Drives: 2023 ZL1
My -NEG terminal is acting the same, but holding for now. I will probably need to replace it eventually, just might do it even if it doesn't fail. Not sure what this issue is, but other friends of my in our local Camaro Club have had the same issue with their 22', 22' and 23'. Hmmmm....
