Old 05-19-2025, 05:21 PM   #1
bjared_454
Drives: 2010 Chevrolet Camaro SS
Squeaking/whistling noise when starting from a stop
Hi! I've noticed this problem on my low mileage 2021 SS 1LE. When I start from a stop, particular in 2nd, I hear a short squeaking/squealing sound. I can also identify this when going at low speed in 1st and accelerating slightly. I do not hear any sound when the engine ISN'T under load, so I'm not sure if it's a transmission/clutch issue or a sound that might just be exaggerated when the car is under load. It's not a horribly concerning sound, but it is weird enough that I figured I would ask.
You can hear it fairly clearly at about 4 seconds in this video. I sat in the passenger seat with my phone out the window and my copilot started slowly in second, which is where the noise seems to be most prevalent.
https://imgur.com/a/3JcGSks
For whatever it's worth I swear I hear the same sound when I start it up in a garage after sitting for a day or two. Not sure if it's some sort of timing thing related to a cold engine/lugging or what.
Any help would be appreciated!
bjared_454 is offline   Reply With Quote
Old 05-21-2025, 09:14 AM   #2
p47dman
Drives: 2024 Camaro 1SS
Although I could not hear it, I'm old, a lot of squeals are fan belts.
Tired again. Next time you hear it, put light pressure on the brake pedal and see if it goes away. Thought maybe a warped rotor or brake pads are worn down.
p47dman is offline   Reply With Quote
