Old 05-12-2025, 03:43 PM   #1
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Arrow Brisk Silver Racing Spark Plugs
I made the switch a while ago... Who else is using them?
Old 05-12-2025, 05:07 PM   #2
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
That's what I plan on throwing into mine to replace the TR7IX. How do you like them? I've heard they seem to run better with less misfires.
Mods being installed-
Old 05-12-2025, 05:19 PM   #3
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
I ran them in my 28psi boost LS motor. Helped with misfires, ran smoother at idle and also didn't foul as easily. I think they're a go-to plug!
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 05-12-2025, 05:36 PM   #4
Z OH 6
Drives: 2021 Red Hot ZL1
Some swear by them, some hate them. Many hardcore racers swear by NGK copper.
Old 05-12-2025, 06:10 PM   #5
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
I switched to them ~ 4-5 years ago and am happy with them.
Old 05-12-2025, 06:47 PM   #6
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Just bought a set of Brisk for my car after watching my buddy nuke his NGK 6510 on a sort of similar combo. Decided I needed something beefier and a bit cooler running.
Old 05-12-2025, 07:37 PM   #7
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - All Bolt On's
+1 !!!!! Brisk RR14S Plugs ! Your late to the "club"
2023 ZL1 A10-Stainless Works 2" Long Tubes & Legend NPP Axle Back•GESI UHO 4.5" CATs•RF BigGulp•Kong 103mm & X-Ported Blower•Griptech 2.30" Upper•ATI Super Damper w/9.45" Lower•THPSI Port Injection w/875cc Injectors•FI Interchillers Stage 2•Brisk RR14S Plugs•Granatelli Malevolent Coils•Katech Low Profile Billet Valve Covers•Katech Duel Fuel Pump•MM Wild 1000HP•DSX Flex Fuel Kit•DSX Billet Lid•DMS 2gal Fender Tank•BMR Cradle Lockout•Weld Solana 18x8 Fronts/17x10 Beadlocks MT ET ST R's•Unlocked TCM•E85=785rwhp/691rwtq +21psi | 1/4=10.5005 @134.21 60ft=1.6182, 1/8=6.8373 @106.11
Old 05-12-2025, 07:54 PM   #8
Crusher Camaro
Drives: 19 ZL1
same here, switch from the NPK to Brisk.
was at the my local tuners request.
Crusher Camaro is offline   Reply With Quote
Old 05-13-2025, 10:10 PM   #9
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
I run the PSPE NGK Ruthenium. Hasn't done me wrong in the 8 years that I've been using them in every application I use them on.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% lower, Griptec 2.5 upper, NGK HR7 Ruthenium plugs, Nostrum 22+ injectors, XDI Goliath HPFP, Katech dual in tank low side pump, Katech oil pump, LME tensioner, DOD delete, LT1 big fuel cam, Jokerz ported blower, MPI lid, GMS hood extractor bracket, Soler ported 87mm (91mm eff) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, 186* LS3 T-stat, Black Widow Angry Housewife/ Corsa NPP mufflers, Borla X pipe, BMR engine mounts, Banks iDash, Lithium Battery, AEM X- Series, HP Tuners, E85, 16.5 psi
834 HP/ 840 TQ
Old 05-29-2025, 02:45 PM   #10
SOCAL.M6.ZLE
Just got a new batch in, if anyone needs some! Click HERE. Just put a fresh set of RR12S in last night!
Can't wait to get her fired up... she has been hibernating for far too long
Old 06-02-2025, 06:51 AM   #11
clg82
Drives: 2020 Camaro ZL1
Hot damn! Only $10.00 for 8 spark plugs?!
Old 06-02-2025, 09:15 AM   #12
Joshinator99
Moderator
LOL that’s each. But the picture is deceiving since it shows you a picture of 8 when you look at the link.
Old 06-02-2025, 09:24 AM   #13
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I might try them next. I have the same set of 6510 TR7IX since 2019 and no issues other than I do get some misfires on cold start before it gets up to around 150 ect.
Old 06-02-2025, 09:50 AM   #14
clg82
Actually I've noticed that as well, never get a code (knock on wood) but do hear a slight misfire on cold startup. I wonder why that is.
