Old 05-02-2025, 09:05 PM   #1
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
Can I run full E85
If I add a flex fuel sensor on my stock LT4 and tune, can I run full E85 or will I be limited to something lower, like E60 or lower?
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 05-02-2025, 09:18 PM   #2
D3adch1ld
Drives: 2019 Camaro ZL1 1LE
Only a mix, you'll have to tune to see where you land. Likely need a low side aux pump too.
Sent from my SM-F956U1 using Tapatalk
D3adch1ld is offline   Reply With Quote
Old 05-02-2025, 09:32 PM   #3
No, your stock LT4 fuel system is inadequate for E85. As D3adch1ld implied, you need to monitor your fuel pressures and see what ethanol percentage your low side starts dropping off, then cut back a bit of the E to have a safety margin.
If you don't want to go through these iterations, professional tuners who do this every day will be able to look at your setup and know off the cuff approximately what your E limit is.
Just as a data point, I have the LT4 fuel system (low side, high side, injectors), +32% fuel lobe cam plus a JMS low side voltage booster, and I can do E60 on a regular basis at ~10-11 psi of boost with my Magnuson 2300 supercharger. I may get away with E65 for a pull, but I don't want to risk it longer term.
The good thing is that performance gains taper off hard beyond E60-65, so you aren't gaining much beyond that. Going with a mix instead of straight E85 also helps a bit with fuel economy, because the engine will gobble up that ethanol like there's no tomorrow.
Old 05-02-2025, 09:33 PM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Agreed. As stated many times before: low side goes out first followed closely by HPFP (w/stock cam lobe) then injectors. JMS voltage booster can extend the low side for a bit. Best bet is to get a real in tank fuel system sooner than later so you have a rock solid foundation going forward. DSX aux is a bad deal, but DSX & Katech in-tank systems are great. Fore Triple if you want big power for drag and/or roll racing.
Old 05-02-2025, 09:55 PM   #5
WiggyB
WiggyB's Avatar
Drives: 2022 Camaro 2SS 1LE
Before I did the port and jms bap I was on e50 with the full LT4 fuel system.
d1sc w/ stage 2 intercooler, Lt4 fueling, JMS BAP, lt2 intake, mamo ptb, kooks 1/78 longtube headers w/ h/f cats, alky meth kit, thpsi port injection
WiggyB is offline   Reply With Quote
Old 05-03-2025, 10:09 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Actual 85% ethanol NO. But most pumps do not have Full E85. Most pumps are E65-78. Being a LT4 car, You "might" be able to do E70 with a JMS and no other mods. There is no need for anything above 60% on a stock car anyway. Just do a 60/40 mix of E/Pump and call it good.
Old 05-03-2025, 10:36 AM   #7
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Old 05-03-2025, 11:56 AM   #8
dreksnot
dreksnot's Avatar
Thanks, all. I was hopeful in thinking I could get a teaser before going all-in just by installing the flex fuel sensor and tune. Might as well wait until doing the "package" in full. Do plan to do DSX in-tank, port injection, FF sensor, bigger air-pump, headers and settle for around 800rwhp.
Old 05-04-2025, 06:20 PM   #9
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
E60 is as far as you will get even bone stock. Can you push E70? yeah but you will drop pressure and actually lose power.
GM Gen V Calibrator
