Old 05-02-2025, 10:57 AM   #1
Baddawg53
Drives: 17 hyper blue 2SS M6
External oil cooler installed, temps went up?
I'm kind of at a loss and looking for some opinions on why this setup didn't work.
As virtually everyone that drives on track can attest to, my oil temps hover around 285-290 degrees. After reading reviews from this forum and looking around, I removed the OEM oil cooler to keep heat out of the coolant, and replaced the aux radiator with the PWR cooler. I installed improved racings 215 degree thermostat and adapter plate and plumbed it all up with 10AN lines.
After getting back on track, I saw oil temps average around 290-295. Kind of surprised by this I started making calls to improved racing and PWR to get help. Unfortunately neither company can come up with any theories. The thermostat tested good, the lines are clear and now I can't come up with any ideas why this setup isn't working. Ambient temps were not high, maybe 80 degrees.
Hoping someone here may have some insight, but I'm doubting it because every post on here I've seen has been tremendously positive. If you have any ideas on this I'm all ears!!
Baddawg53 is offline   Reply With Quote
Old 05-02-2025, 11:34 AM   #2
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Hey buddy, looks like you purchased the right stuff... so the fix should be easy. I am sure you have checked everything 3 times by now, but a few questions if I may.
1. Have you double checked your oil level, and assuming it's good, how much total oil did the system take after the cooler was installed? Should be near 12 quarts.
2. Have you confirmed that the oil flow is going in the same direction? as the thermostat is directional.
3. Assuming you have, and the plumbing is directionally correct, can you confirm that the PWR cooler is getting fluid? Perhaps you can take the surface temp of the cooler using an IR gun before and after the thermostat should have opened? Example (when you oil is at 180F the cooler should be much cooler than that after driving) but when the oil reads 230F and you pull over, the IR should read near 22-230F...
4. What weight oil are you running?
5. Lastly, how has you oil pressure been before and after the install (hot idle vs crusing)
SOCAL.M6.ZLE is online now   Reply With Quote
Old 05-02-2025, 12:04 PM   #3
Baddawg53
Good questions!!
I believe I was actually over 12 quarts, closer to 13. I run mobil 1 0w50 racing oil. The plumbing was in the correct orientation, and improved racing stated that while not as efficiently, it will still function if plumbed backwards. PWR stated the cooler is non-directional. The oil pressure I didn't deeply investigate but I did look quickly and saw it was consistent with what I had previously. I'll do a deeper dive into that data
I did not measure with an infrared camera, this is a good idea and I'll do this my next track day. I'm solely going by the gauge on the dash and the data from the AIM solo DL.
Old 05-02-2025, 12:51 PM   #4
SOCAL.M6.ZLE
Originally Posted by Baddawg53 View Post
Good questions!!
Do you have something like this you can use to make sure the thermostat is opening, and hot oil is circulating into the cooler after 215F ?
Old 05-02-2025, 02:14 PM   #5
Baddawg53
I put the thermostat in the oven and watched it close when it got hot, it's functioning correctly. I don't have that particular one, I have a flir camera that can hook into my iPhone, I'll use that and see if I can see the oil flow. My biggest hurdle is that the car is non op, not road legal so it's tough to test.
Old 05-05-2025, 09:34 PM   #6
Racerbox77
Drives: Iroc-Z
I would think you would need a larger cooler or put one on the other side? When I did my C6z06 I had 2 coolers that size.
Racerbox77 is offline   Reply With Quote
Old 05-05-2025, 10:12 PM   #7
Baddawg53
I might be that anomaly that needs that, seems as though literally everyone else that installed this one has had the expected results.
At this point, I'm leaning towards installing the OEM cooler and running this off a sandwich plate, having both. Which is kind of along the lines of what you're saying.
My hope was to keep the heat of the oil out of the coolant, but seems I don't have that option.
Old 05-07-2025, 10:10 AM   #8
calypso50kid
Drives: 2018 zle, 03 cobra, 92 mustang lx
Is this on a SS or a ZL1? air flow is key, if its on a SS where did you put the cooler? are you getting enough airflow and do you good enough to evacuate the air after its gone through the cooler?
Owner and driver of the worlds fastest naturally aspirated drag radial car. Hays Consulting and Performance
4.58@151 BBC powered 585 ci 9000+ rpm
https://youtu.be/wSz2OedlNSI?si=SnPoqreXFQ7NLYX8
2018 ZL1 1LE 416ci LME long block, 2650, reflex port injection, full e85, tick performance tr6060, monster triple disc, DSS drive shaft, g force axles.
calypso50kid is offline   Reply With Quote
Old 05-07-2025, 12:03 PM   #9
Baddawg53
This is an SS. This cooler is designed to replace the auxiliary radiator. I tend to agree that it's probably airflow related because everything else seems to be working.
The OEM ducting from the bumper through the fender liner is in place, I do run a 315 front tire and the fender is vented. If you have a suggestion on how to test the airflow without a wind tunnel I'd love to hear it.
Old 06-06-2025, 01:11 PM   #10
Baddawg53
Just an update, I installed a lower temperature thermostat and it made no difference in my track oil temps, they're still 285-290.
I had hoped to keep the oil and coolant separate however I don't think I have much choice but to reinstall the OEM cooler and run that as well as the aftermarket oil cooler. I'm pretty disappointed in the results here, giant waste of time and money.
Old 06-06-2025, 04:27 PM   #11
SOCAL.M6.ZLE
Hey Mark, I was thinking, have you sent your FLIR images to PWR yet? I was looking at them again and thinking that the "cold" side of the cooler should still be showing a heat gradient from bottom to top, and it doesn't. Perhaps as a last effort you should share those images with PWR and request a replacement cooler to test again. there might be a unique manufacturing issue with your cooler that is not allowing oil to pass through the bottom of the cooler. Just a thought.
Old 06-06-2025, 04:59 PM   #12
Baddawg53
Interesting thought there, when I looked at the temp differential left side vs right side I assumed it was divided down the middle. That's a good idea, I'll get some clarity on that.
Old 06-06-2025, 10:04 PM   #13
That1guy_tim
That1guy_tim's Avatar
Drives: Camaro 1ss
Where did you mount the cooler ?
That1guy_tim is offline   Reply With Quote
Old 06-06-2025, 11:03 PM   #14
Baddawg53
The cooler replaces one of the auxiliary radiators. I put it on the driver's side.
