Old 04-30-2025, 11:48 PM   #1
bcasurvey1
Drives: 2019 ZLE sold now 2021 ZLE
adding subs to 21 zle w bose using ******** harness
hi, so i have a 21 zle with bose, i added a amp and loc and used the ******** harness. everything is wired correctly and the subs are playing but i lost sound to my two door speakers. the harness looked correct but i didnt test it with an ohm meter, before i start ripping everything apart.
has anyone used their harness and run into a problem with the front speakers not working?
im thinking it may be a bose signal issue cuz everything looked clean and correct?
one other choice may be the loc not set to proper ohm setting, im really not sure where to look?
thx for any help-also my search does not work on this site if anyone knows why or is it not working for everyone?
bcasurvey1 is offline   Reply With Quote
Old 04-30-2025, 11:49 PM   #2
bcasurvey1
sub thump sry i didnt know it would do that lol
Old 05-01-2025, 11:56 AM   #3
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
One of the board admins had an issue with sub thump, so they banned that word on these forums, LOL.
Do you have the front speakers on a separate amp, or are they still on the Bose amp? I only added a LOC, single channel amp, and subwoofer to my Bose system. I haven't had any issues with any other speakers cutting out. Did you get/hook up the ANC delete harness as well?
I have some pics of my installation scattered throughout my Car Journal linked in my signature. Check those out to see if any of my pics might help. Start at the end & scroll backwards, since I have more recent pics at the end.
My Camaro Journal
Old 05-01-2025, 01:17 PM   #4
bcasurvey1
i figured it out and i hope this helps someone cuz i almost bought new door speakers thinking i blew them with my low tone when setting up gains.
but the answer is you must set the "load select" to 60 ohms so the bose amp will see the front door speakers. everything works great, a little to good actually, i should have went with one 12" sub, im to old for dual 12's lol, oh and yes i did ans delete also.
Old 05-01-2025, 01:19 PM   #5
bcasurvey1
pics below
Old 05-01-2025, 01:29 PM   #6
bcasurvey1
thanks for your help
everything is on bose
i added Skar loc SKE2LOC , amp SKv2-2500.1D and Skar Audio SVR-12 12-inch dual 4 ohm car subwoofer, running at 1 ohm.
its a very good setup and im all in for under $850 way overkill for me
sum thump t harness with anc delete
ty
