Old 04-29-2025, 11:03 AM   #1
wang970305
Drives: 2021 Camaro 2SS
Is it worth to port LT2 IM snout
I have a GPI ported LT2 IM, however, the snout was not fully ported to 95mm. If I get a local shop port the snout to true 95mm, will it give me more power? Also, would I need to a retune?
2021 Camaro 2SS Summit White
Kooks 1-7/8'' LTH with high flow cats, Corsa Catback Exhaust, Roto-Fab CAI, Ported LT2 IM, LT5 95mm TB, Lethal Garage Flex Fuel Sensor, Mishimoto catch can, AEM Wideband.
wang970305 is offline   Reply With Quote
Old 04-29-2025, 10:43 PM   #2
vince3
Drives: 2022 Vivid Orange LT1-M6
2. Port-Matching to the 95mm Throttle Body
• Description: Enlarging and shaping the LT2’s inlet to match the 95mm throttle body’s bore (ensuring a smooth transition, no step or mismatch) minimizes airflow disruption at the TB-intake interface.
• Power Gain:
• Without Port-Matching: The 95mm TB’s full potential is slightly restricted by the LT2’s smaller inlet (stock LT2 inlet is ~87-90mm).
• With Port-Matching: Adds 3-7 RWHP, 2-5 lb-ft over unported LT2 + 95mm TB. Gains focus on high-RPM (5,500-6,500 RPM), as the smoother transition maximizes TB flow.
• Dyno Evidence: LS1Tech and Texas Speed note 3-8 RWHP from port-matching on LT intakes, with smaller gains (3-5 RWHP) on already-ported setups (2020 posts).
Grok says 3-7hp in a typical FBO car. I was going to get my MSD ported in Houston and the only local person I would trust would be Greg Good.
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph
vince3 is offline   Reply With Quote
Old 04-30-2025, 01:55 PM   #3
wang970305
• Power Gain:
Man, thanks for your input! Where does Grey work at?
Old 04-30-2025, 07:31 PM   #4
wang970305
Also, I have a FBO ECM tune already, if I ported out the IM snout, would I need a retune?
Old 05-01-2025, 09:30 AM   #5
vince3
Grok says it would most likely need to be tuned to see the gains. Without tuning, it would run slightly lean from what it says. Who did the tune? Who did you get to install your headers? I've found one shop in the houston area that is reasonable (Ace Performance Exhaust) but I'm concerned about getting it installed without leaks.
