Old 04-29-2025, 10:44 AM   #1
vince3
Drives: 2022 Vivid Orange LT1-M6
MSD Intake Install questions (thorttle plate, orings and parimeter gasket)
I bought a used MSD Intake, and I noticed that I'm missing the TB seal plate and gasket - figure 14 below in the instructions. If I'm installing a 95mm tb, do I need this?
https://documents.holley.com/4785a06...b8514b2293.pdf
Also, the intake is 4-5 years old, and I'm considering replacing the orings and perimeter gaskets. The current gasket is the black one and I would replace it and add gasket seal around the areas that are known to have issues.
Any thoughts on whether I should do this? My old MSD had some leaking problems from when they 1st came out in 2016/2017.
2022 Vivid Orange M6 LT1 - 2" ARH headers with cats and offroad setup (full system,), 3" ARH Pure Thunder mufflers, ported MSD intake, Soler 95mm tb, Rotofab CAI, E85 flex fuel, tuned by Jason@snackbartuning, Forgestar D5 18x8 fronts with 245/40/18 and Forgestar D5 17x10 rears with 275/40/17 summer tires.
Old car 2016 M6 SS - MSD intake, Rotofab, 2" ARH headers with cats, E85 with EFI Tuning. Best ET: 11.7@122mph
vince3 is offline   Reply With Quote
Old 05-01-2025, 09:58 AM   #2
wnta1ss
Drives: 2017 Camaro 1SS
No, you not need the metal plate or paper gasket for your 95, as they are just intended for mounting a stock (87) throttle onto the large opening of the MSD. Metal plate would go onto the MSD o-ring and the paper gasket would then seal the throttle to the plate when mounting an 87. With a 95 though, you can just mount the throttle right onto the o-ring on the front of the MSD, like you'd mount a 103. I have done this, put a 95 directly onto an MSD, and ran the car for a few years like that.
Old 05-01-2025, 09:59 AM   #3
vince3
Thanks!
Old 05-01-2025, 12:52 PM   #4
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
+1 Vince . My car ran fine with the MSD + 95 TB straight on. Later I did add a Soler Performance 95-103mm adaptor to smooth out the laminar flow- not a likely concern for most folks- lol. Even after a canned tune (via a Bully Dog/BDX tuner to provide a bit more fuel), the car continues to run very well.
You can pick up a full set of gaskets for the individual intake ports at Amazon-
https://www.amazon.com/Dtomi-Manifol...7+Chevrolet+SS
Ventmaster is offline   Reply With Quote
