![]() Drives: 2018 ZL1 1LE Join Date: Jan 2024
HHHEEELLLPP
Help,
18 ZLE M6 here. Real bad bog down on launch, just when trying to get from get go and mash the pedal, car nearly stalls now. Did not have that bad of bog down before. If I drive slowly and mash, no problems. Just from launch. Tried multiple times with different rpms, same result in competition mode. When in touring mode, no problem, just wheel spin. Car has o2 cel coming and going. forgot the code, bank 2 from fat to lean or something like that.
That Camaro Life
![]() 2018 Camaro ZL1 1LE 2017 Camaro 1SS - SOLD 2019 Camaro I4 2.0T - SOLD 2024 Mazda CX-50 - Winter beater 2021 Dodge Durango R/T TnG - SOLD 2019 Mazda 3 - SOLD 2013 Dodge Journey R/T - SOLD 1985 Porsche 944 - SOLD 2011 Volkswagen Jetta - SOLD 2000 Honda Prelude - SOLD 2007 Tayota Matrix - SOLD 2004 Mazda Protege - SOLD 2004 Pontiac Vibe - SOLD 2000 Ford Focus - SOLD |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
Did you check connections to mass air flow sensor? Is this after a recent filled up, even from a gas station that you haven't used before. More detail of how it was running before this issue would help, and anything you remember changing or adding or happening right prior to it acting like this?
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Sarcasm loading --------
check for boost / vacuum leak
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
#4 | |
That Camaro Life
Thank you Al Oppenheiser!
OP you were talking about oiled engine air filters and alternate (rotofab) intakes a while back. What state of modification is your car in now?
P013C bank 2 sensor 2 slow response rich to lean? Don't see how a bad downstream sensor alone would severely affect drivability. Sounds like there are more yet undiscovered problems. If the car doesn't like air, then suspect a fuel issue. But I could see a MAF taking a dump if it got filter oil on it. |
#7 | |
That Camaro Life
#8 | |
That Camaro Life
#9 |
Ahh okay P015D is delayed response lean to rich on the primary sensor ahead of the cat, so yeah if it's bad or there's an intermittent wiring fault on that circuit (loose pin, iffy ground, etc.) it could affect drivability.
My understanding of Track mode is that it was programmed to prevent wheel spin, because loss of traction is bad on the track for obvious reasons. My personal experience is that Sport allows much more rear wheel spin than Tour, and Track less than Tour in my A10. I would expect Sport to be likewise more forgiving of launch traction loss on the m6 1LE as well? I know my A10 vert is pretty much an orange compared to the M6 1LE apple. Curious what tires and what ambient temps is all this happening at? |
#10 | |
Yes, track mode is more aggressive. I was launching last year and had typical small bog down like all M6s do. Now it just flat out terrible. It was like trying to get going while driving a moped in Syria. I got PS4S tires that are nearly new and it was 23C yesterday.
That Camaro Life
