Old 04-23-2025, 08:27 PM   #1
nicklvsa
Drives: 2023 Camaro ZL1 1LE
Slight ticking noise when ZL1 hood open
Hey folks,
I have a 2023 Camaro ZL1 1LE and happened to have the hood open this evening while the car was running. I noticed a slight ticking noise at idle and wanted to confirm with others to see if this is something I should worry about or if I'm just worried for no reason. My original thought was that the noise was coming from the fuel system and was normal, but hope to get some more opinions.
Video link: https://www.youtube.com/shorts/XP6Y2v2lY2c
Thanks!
nicklvsa is offline   Reply With Quote
Old 04-23-2025, 09:00 PM   #2
SWFLZL1
Drives: 2022 ZL1
Sounds normal to me.
2022 ZL1 M6 Coupe
SWFLZL1 is offline   Reply With Quote
Old 04-23-2025, 10:11 PM   #3
Completely normal. The ticking you hear is most likely injector noise.
I will say that these online videos can't reproduce the actual sound profile, so one can't be 100% sure, this isn't proper diagnostics My engine ticks much louder to begin with (because of the long tube headers), but it's barely audible on recordings.
Old 04-24-2025, 05:49 AM   #4
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Completely normal. The ticking you hear is most likely injector noise...
2nd what he said! Mine sounds very similar.
One thing I had until I figured it out was a header flag exhaust leak. I had an annoying ticking sound once and for the life of me, I couldn't find anything obvious, so I just chalked it up to either engine noise like the lifters or injectors. Then, one day my brother in-law was over and I wanted him to hear a track mode cold start. After starting the car, I popped the hood so he could see the mods. He quickly said, hey you need to fix that exhaust leak. I was like what? So, we put the car on my Quick Jacks and he showed me black carbo lines by the header flag, we loosened up the flanges and re-tightened and fixed this issue.
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 04-24-2025, 06:26 AM   #5
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
++injectors
These cars are pretty 'loud' if you've never heard one before comparatively speaking.
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 04-24-2025, 08:11 AM   #6
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Normal injector tick.
Sounds quiet compared to most ZL1s.
