![]() Drives: camaro ss Join Date: Nov 2023
Big power on stock lt1
Curious what is everyone’s thoughts on a completely stock motor 6th gen camaro ss on E85 (with supported fueling) and about 8-10 lbs of boost. Do you think this shit would blow up after 1 pull or it would live for a while.
For context car has a p1sc-1 blower headers, Xpipe and dual in tank DW 400 pumps with FPR i want to do full lt4 high side fueling on E and pulley down all while stock motor. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Well I can tell you this. I popped 2 pistons 2 rods, and cracked a crankshaft, without boost and with only daily mods: Headers, LT2, 95mm TB, CAI, E85, X-Pipe and a Tune.
But then again I'm told I'm the proverbial lottery winner more often than not. In your case looking at about 600-650+ hp/tq with a SC. At that time I was only at about 470 rwhp and rwtq, based on guesstimate, you'll be at about 550 rwhp and rwtq or more with the other mods. Take that for what you will. I am sure the SC guys will chime in with sound advice.
![]() ![]() ![]() ![]() ![]() Drives: '23 1SS Sharkskin A10 Join Date: Sep 2018
Whoa, that's nuts.
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune l GM Lowering Kit Ported LT2 Intake Manifold l Ported 95mm LT5 TB l BMR Rear Cradle Lockout Kit Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l 480whp/467wtq |
#4 | |
Moderator
Fwiw I made 600whp on E82 @ 7-8 psi back in 2019 with cat delete pipes, LT5 tb, and rotofab big gulp. Fuel system was LT4 fuel injectors, LPE big bore HPFP, LT4 tank pump with JMS. TR7ix plugs.
2020, I dropped 2 pulley sizes(10-11psi), big gulp, 103tb, +30 injectors, E60 fuel, metco breather. (680-700whp) 15k miles and a plethora of hard pulls later still going strong. As I have mentioned in several of threads like this one in the past. Proper fuel system, tuning, and Ethanol are key to longevity.
2016 NFG SS A8/Whipple 2.9/Fuel System/Flex Fuel Last edited by KingLT1; 04-14-2025 at 11:49 PM. |
#6 | |
![]() Drives: 2023 Riverside Blue 2SS Join Date: Sep 2022
#7 | |
#8 | |
#9 |
Yes stock motor. Another example linked below.
https://www.camaro6.com/forums/showthread.php?t=610371
#10 |
![]() Drives: Chevrolet Camaro Join Date: Apr 2022
Stock pistons and rods here... Enough fuel with a good tune and you'll be fine. A cam will give you a little more room with the fuel lobe and less dynamic compression.
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT5 Throttle Body, MSD Intake, LT4 HPFP, LT4 Injectors, JMS BAP, 93 + Boostane - 750+WHP
#11 |
I am just glad I could fill the statistical quota for everyone else that way they do not have problems with their builds.
#12 | |
![]() Drives: 2021 Camaro 2SS Convertible Join Date: Jan 2025
#13 | |
#14 | |
Moderator
King tunes his own ride (and others).
