Old 04-14-2025, 06:36 PM   #1
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Arrow BACK UP CAMERA HACKING ???
Hey guys, asking for an illiterate friend.
Any know if it is possible to convert the "back up camera" to a constant "rear view" camera when racing?
Old 04-15-2025, 10:18 AM   #2
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
LOL. Install a non-resistor rear back-up light bulb.
**edit** - must install LED backup light bulbs to do this
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 04-15-2025, 10:32 AM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I’d check with Gen5DIY. I thought they were able to unlock use of the rear camera at any time you want to use it.
Old 04-15-2025, 04:06 PM   #4
SOCAL.M6.ZLE
Thank you sir
Old 04-15-2025, 07:07 PM   #5
dreksnot
dreksnot's Avatar
Actually, this would work. Just put a SPST switch in the cockpit with a 200ohm resistor inline. Bypass resistor and rear camera comes on. Flick the switch to put the resistor inline and the camera goes off. Would most like just have to do this with one bulb and resistor (not have to do it with both rear lights). Forgot to mention a very important part and that's having to install LED backup light bulbs, like the LASFIT L2 7440 LED bulbs.
I know this because I had to install a resistor to keep the camera off on my 2021 after installing LEDs.
Old 04-15-2025, 07:55 PM   #6
This is not a solution. The car will think the driver is backing up, causing who knows what random side effects.
An actual proper way is what Josh mentioned briefly: Gen5DIY can reprogram the HMI and allow any cameras to be turned on manually at any time. Link: https://www.gen5diy.com/collections/...ckage-8-screen (this is for the 2018, one would call them to inquire about availability for 2019+ cars).
Old 04-16-2025, 03:58 PM   #7
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
I heard that if you simply unplug the reverse lights the camera will stay on(only downside is that you lose use of PDR). I never tried it myself.
Christian1LE is offline   Reply With Quote
