Old 04-13-2025, 04:59 PM   #1
bcasurvey1
Drives: 2019 ZLE sold now 2021 ZLE
does anyone know what this is?
i just bought a new to me 2021 ZLE and i dont know what this is? i think its aftermarket cuz my 2019 ZLE didnt have one idt?
when i pushed the button the fuel pump kicked on for about 5 seconds, so im thinking its a fuel pump relay??
bcasurvey1 is offline   Reply With Quote
Old 04-13-2025, 05:02 PM   #2
Deacon Blues
Drives: 2024 Camaro 1SS M6
Kill switch for fuel pump?
Deacon Blues is offline   Reply With Quote
Old 04-14-2025, 09:52 AM   #3
bcasurvey1
i dont think it is a kill switch cuz the fuel pump started not stopped?
Old 04-14-2025, 11:19 AM   #4
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
fuel pump voltage booster?
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 04-14-2025, 01:02 PM   #5
Looks like some aftermarket security device. Most likely not a voltage booster, those look different and are much larger with beefy cooling fins.
Old 04-15-2025, 05:00 PM   #6
bcasurvey1
here's a couple more pics, when i push the middle button the fuel pump kicks on and the blue light comes on and it stops when the fuel pump reaches full pressure, is what it sounds like, i followed the wires to behind the dash near the obd2 port but im to big to get under there and see what it goes to. i do have a P3 gauge there also but i didnt see anything on their site that looks like it.
Old 04-15-2025, 05:51 PM   #7
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
Fuel system priming circuit? You have aftermarket fuel pumps in the tank that maybe don't have a check valve in them so they bleed down if car sits there for awhile?
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 04-16-2025, 04:41 PM   #8
ctrlz
I like this guess.
What do LED's do when car is running?
I'll guess:
White is "Ignition on"
Green is "pump energized"
Blue is test button.
This look like it might be a custom module. A PCB kit with a semi-custom mounting box.
Old 04-17-2025, 07:47 AM   #9
nighttowl
nighttowl's Avatar
Low side aux pump controller?
Old 04-17-2025, 08:13 AM   #10
Deacon Blues
Just out of curiosity, what would the benefit of this type of modification be? My car is stock, but I'm definitely trying to learn more about cars since most shadetree mechanic stuff I've done is limited to basic mechanical and maintenance (brakes, oil, O2 sensors, etc )
Old 04-17-2025, 08:16 AM   #11
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Looks like a low side pump controller for an Aux pump setup. Crawl under the car and check to see if the fuel tank has been tapped.
Old 04-20-2025, 10:26 AM   #12
bcasurvey1
Sir, you are correct see picture. Fuel tank is tapped and seeping fuel.
one of the wires goes to the DSX sensor as well (it was hard to trace).
So what we be the need for this? there is already one in the tank plus the high pressure pump. (I dont like seeing my tank tapped like that cuz its a spot for future failure, gas leak. next step is to see where the fuel line taps in?
I saw a youtube video on how to tap and install in fuel tank and they put some kind of sealer around the fitting, does anyone know what sealer you would put around a fuel tank tap? i need to reseal it and i dont want to use JB weld but i cant think of what would be best?
Old 04-20-2025, 11:05 AM   #13
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
DSX and the green goo
Drill-n-tap through what is not more than 1 to 1-1/2 threads thick curved bit of fuel tank seems like a bad idea to me. Any flex at all and it'll try to open itself up.
If that's DSX standard procedure (I saw the video with the green goo), then the green goo should be included in the DSX kit. Yep, there it is. Might be this one but there is no picture, so you might want to give them a call (314) 396-7333 to confirm as well as ask them for advice on how to address the leak (be it just with sealant, or if they have some other solution).
Old 04-20-2025, 05:03 PM   #14
bcasurvey1
thx for your help and i will call DSX, i don't see the relay that started this post on their website? maybe its an old design or someone added to the system?
