Old 04-09-2025, 03:08 PM   #1
James Montigny
James Montigny's Avatar
Drives: 2017 Camaro 2SS
Can I just loop the tranny to differential cooler lines?
I broke the differential in my 2017 SS a8
The replacement arrived but doesn't have provisions for cooling lines. Can I just loop those? It's a street car that might see the strip, but will never run a circle track.
James Montigny
2017 Camaro 2SS A8 - Krypton Green
Magnuson 2650 @ 13psi, Forged TSP Rods/Pistons, TSP Ported Heads, BTR PD Cam, Aeromotive Low Side, DSX Flex, LT4 HPFP, 103mm TB, Big Gulp, Meth.
Built by Killer Performance, Tuned by Justune.
James Montigny is offline   Reply With Quote
Old 04-10-2025, 09:22 AM   #2
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
I bought a new one from GM for a direct replacement for what I broke. Trying to understand what models did not have the differential cooling? I thought all SS models came with the rear diff cooling. I would think if it was something that was there previously, you would want that on the replacement. Sorry I can't give you an answer, but like I said I think you would want the extra cooling?
dmcmahan60 is offline   Reply With Quote
Old 04-10-2025, 10:13 AM   #3
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
The SS convertibles don’t have differential cooling.
Old 04-10-2025, 01:14 PM   #4
DeuceCam
Drives: LT1
LT1 model doesn't have a diff cooler.
DeuceCam is offline   Reply With Quote
Old 04-10-2025, 03:50 PM   #5
cdb95z28
cdb95z28's Avatar
I'm kinda surprised a non-1LE SS has diff cooler.....that being said, loop the lines, complete the circuit. Capping them would be bad.
EDIT: I checked the VIN on my bro in law's old 2018 SS, yep, it had the diff cooler.
"KEEP THE FAITH"-Fbodfather
Old 04-11-2025, 09:11 AM   #6
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
The standard SS was also considered a track ready car by Chevy and warrantied on track. The LT1 is the one that Chevy does not consider track ready out of the box.
Current: 2023 2SS 1LE
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 04-11-2025, 12:30 PM   #7
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Agreed. The SS also has the two auxiliary radiators and a dedicated transmission cooler as well.
