Old 04-08-2025, 10:12 AM   #1
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Arrow FUEL FILTER OPTIONS
Hey guys... for those who run an auxiliary fuel filter, was curious to know what brand you went with and where you installed it?
Photos please
Old 04-08-2025, 11:01 AM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I use a small DW filter. It's got a replaceable filter and is something like 6-microns (at least as small as 10) or something pretty small.
Because I was running electrical from the SSR in the trunk to the REFLEX out front, I ran it close to where the DSX aux' pump set-up used to be. I used some rivnuts to mount the filter bracket, Vibrant PTFE hose and most of their fittings. I split at the OEM QC, and branched off, trying to keep bends and angles to a minimum. There were easier ways to do this, but I have criteria I'm trying to stick with, and this was just a little more work, and a little less expensive (except for time, lol).
It's probably worth noting, that for those that don't know, it seems like any of these multi-pump buckets/modules require you to ADD a fuel filter. I believe it's because the OEM fuel filter is IN the bucket/module and auxiliary pumps take the space where that filter WAS. So - you have to add one. I think there's one external one that mounts behind the blower, near the firewall, FWIW, too.
'20 ZL1 Black "Fury"
Old 04-08-2025, 01:35 PM   #3
SOCAL.M6.ZLE
Beautiful install !!! Love that Flashlight BTW HAHA
Looks like you ran -8an lines?
Old 04-08-2025, 02:51 PM   #4
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
I went with the FUELAB 828 filter, I wanted something larger to help minimize any flow restriction. I'm running -8AN lines to help offset the tighter bends in my routing. Planning to mount it in the same spot as radz28, but I’ll need to fab a custom bracket since the 828 is a bit larger than most filters people run.
I’m not a fan of the underhood filter setups that come with some of the complete kits. Heating up the fuel before it even reaches the high-pressure fuel pump, and eventually the rails just seems counterproductive.
I’ll post some pics once it’s installed—hoping to make it my Easter weekend project.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
Old 04-08-2025, 04:39 PM   #5
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I’m running a -10 AN Fore Innovations filter. We made a custom stainless steel bracket and mounted it under the car (above the road noise panel on the passenger side). I’ll have to find a pic but think it’s posted in my build thread.
Old 04-08-2025, 10:17 PM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Just that part. Maybe later I'll redo the low side lines.
Old 04-11-2025, 09:51 PM   #7
SOCAL.M6.ZLE
Very cool, sounds like we will have similar set ups. Please share pics when you're done!~
Old 04-14-2025, 04:24 AM   #8
Roddrz
Roddrz's Avatar
Drives: 2022 Camaro V6 2LT Convertible
Here is another fuel filter setup
1) Fuel line from tank into engine bay
2) 6AN Male x 3/8" SAE Quick-Disconnect Male Adapter With Zinc Finish - Russell Part #640940
  • This fitting connects to fuel line coming from the tank.
  • A retention clip is also used.
3) 6AN Proclassic 180 degree swivel - Russel Part #613505
4) 6AN Hose
5) 6AN ProClassic 45 degree swivel - Russell #610095
6) Performance World 95206 6AN 10 Micron fuel filter
Grounding connectors to clamp filter to strut tower brace
7) 6AN 150 degree swivel
8) 6AN Hose
9) 6AN ProClassic Swivel 90 degree swivel - Russel Part #610165
10) EFI Adapter 6 AN Male to 3/8 SAE Quick Disconnect Female Screw - Russell Part #644123
11) Fuel line to engine
Roddrz is offline   Reply With Quote
Old 04-14-2025, 10:15 AM   #9
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
This is what Katech installed on mine. If I remember correctly, I understood that it also hides the Flex Fuel sensor as part of the filter/unit install?
https://katechengines.com/i-30498304...ilter-kit.html
I will try to get better pics of it later this evening.
Thanks
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
