Old 04-07-2025, 10:24 PM   #1
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Cool Rear Tow Hook/Trailer Hitch
Well since there was no decent tow-hook setup for the 6th Gen Camaro ZLE... I decided to make my own. I am racing in this week's GridLife Track Battle and one of the rules mandates the car must have a rear tow hook. I figured that I would build one that not only would exceed the 7K requirement, but also will carry a 400# tongue load. LMK what you think!
Patriot Motorsports USA is offline   Reply With Quote
Old 04-08-2025, 06:56 AM   #2
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
I have the OEM one and use it to transport tires to events.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 04-08-2025, 10:50 PM   #3
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
i like it, the fact that you can barely even tell its there is great
Old 04-09-2025, 09:01 AM   #4
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2020 2SS
Great solution!
Bad Anvil Garage is offline   Reply With Quote
Old 04-09-2025, 12:04 PM   #5
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
That looks great! How is it mounted? I assume using the same bolts as the bumper?
I have the Curtis one and although it is functional, it's much lower and occasionally scrapes. This would be a better solution. You might have to fabricate and sell to me! lol
Dabjbr is offline   Reply With Quote
Old 04-14-2025, 09:43 AM   #6
RallyRunner
Drives: 2020 RG LT1 M6 / 2019 4runner
looks good! i have a Curt class 1 and use it to jam over to the local mtb trails pretty often. hardest part of the install was just getting the bumper cover on and off.
2020 LT1 | Rally Green + Ash Gray | Tremec | NPP | Sunroof
RallyRunner is offline   Reply With Quote
Old 04-18-2025, 07:12 AM   #7
Cool Trailer Hitch Passes Gridlife & NASA Tech Inspection
This past week was a wild one with Gridlife Track battle and two days testing on track for the class I was competing in. As part of the requirements for racing, a tow hook needed to be on the ZLE to pass the Tech Inspection and I am happy to report my hitch does with flying colors!!
If anyone wants to order one, I am having new mounting plates stamped out this week to build five more. Yes, this does require a small 1.25" square hole be made into the bumper but it has to be so the rated pull of the car is in line with the attachment points for the highest recovery strength possible. Once installed, you can use any hitch you like in the receiver, but the billet Mooseknuckle one we used passed tech scrutineers without issue and it looks killer! Send me an email if you wish to place an order.
receiver hitch, tow hook, trailer hitch, zle
