![]() Drives: 2014 Ford F-350 Join Date: Sep 2023
Road Course SS1LE Tire Wear F vs R
What is everyone experiencing, in regard to tire wear? Specifically, front tires versus rear tires.
I have a coupon with my local dealer that gives me the fourth tire for a dollar, but all four tires must be identical. My first thought is to get four rears, since they are more expensive. I already have two sets of wheels and tires. What is everyone finding? I do Sunday cruises and road courses. I might start doing some auto cross, but that will be minimal. I’m guessing the fronts wear faster than the rears, but I don’t have enough miles or tires to really know. I do have a track alignment.
2024 Red Hot 2SS 1LE w/BCD, PDR
2014 F-350 Crew Cab Cassis Cab Dually 6.2L w/4.30 2014 Hyundai Elantra GT 1995 Buick Roadmaster Estate |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Fronts wear faster than rears especially with track alignment and actual track use.
"KEEP THE FAITH"-Fbodfather |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I believe i go through rears more than fronts and thats a spec street alignment, no burn outs, no track, but i drive it hard. Remember its toe that kills tires, not camber. Camber is tte only difference in street and track alignment.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Oct 2011
I also find its not like you go through 2 rears for one set of fronts
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
![]() ![]() Drives: 2020 SS 1LE Join Date: Aug 2020
When stock, and even with track alignment, my fronts corded on the outside shoulder first. I now run wheels and tires and rotate. It’s always the shoulders that go first. That said, I’m probably 75/25 track/road use.
![]() Drives: 2023 Camaro SS1LE Join Date: Oct 2023
With mostly track use, front tires wear quicker than rears. If you are going to do a good amount of track days and you are staying with the stock sizing, then I would buy extra fronts with that discount.
If you later on get into more tracking and go with a set of dedicated track wheels/tires, then you have the option to go with a square setup and can rotate them front-rear to even out the wear.
2023 Camaro SS1LE
1989 Trans am GTA |
#7 | |
I'd type this but i already answered you on Facebook.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
#8 |
Thank you, for the responses. Here and Facebook!
