Old 04-05-2025, 01:51 AM   #1
veaceonee
Drives: 2016 Camaro SS
Magnuson Heartbeat P2230
I have a 2016 Camaro SS that I recently purchased that came installed with a Magnuson Heartbeat Supercharger. It ran great until I got the opportunity to bask in the warm amber glow of the check engine light. It is a code P2230 Barometric Pressure Sensor 'A' Circuit Intermittent/Erratic. Tried clearing it and it comes right back immediately. Does anyone know where that sensor is located so I can change it out? Is it the one on the back of the blower (ACdelco PN 12592525)?
Thanks in advance
PS sorry for the excruciatingly large picture
veaceonee is offline   Reply With Quote
Old 04-05-2025, 04:39 AM   #2
veaceonee
UPDATE: Rescanned the car tonight. It now has a P00C7 and a P2228 active. The P2230 is still active as well.
Old 04-07-2025, 09:44 AM   #3
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
Back of the motor, driver side head.
Check out my youtube channel
https://www.youtube.com/@evans.educa...ocxUzC1ferqeg8
Full SPL suspension / Ported blower / NW 103mm / Rotofab BG / 2" Headers / Ported heads / Upgraded Valvetrain w/ DOD delete / Custom 38% Cam / C7.R Timing chain / Katech Oil pump / BMR motor mounts and chassis braces / Katech 174* Thermostat / Pierburg Supercharger coolant pump / PLM HX / JMS voltage booster / ATI Damper w/ 8.6 Lower / MM Mild catch can / ADM Resevoir / soon to come...
Rebuilt Engine / XDI +30% injectors / PWR Oil cooler setup / GMS Hood bracket
760 Whp / 700 Wtq E50
Old 04-12-2025, 12:55 AM   #4
veaceonee
Replaced MAP sensor with a GM unit. CEL was gone for about 30 minutes, then came back. Same P2230 code.
Old 04-21-2025, 10:21 AM   #5
Evansa22
Evansa22's Avatar
Did you change the sensor i circled? That is the barometric sensor which is associated with p2230. If you changed the MAP sensor then that would be a different code. Their are actually two MAP sensors, one on the front of blower pre rotor pack, and one on the back post rotor pack entering the motor.
Just want to be clear as you stated you replaced the MAP sensor which is different than Baro Sensor.
Old 04-21-2025, 10:23 AM   #6
Evansa22
Evansa22's Avatar
Also check the wiring to each and make sure nothings burnt or broken. Forgot you had multiple codes
Old 04-21-2025, 11:16 AM   #7
SpeZ
SpeZ's Avatar
Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30
Uhm these are barometric codes.
100% this is the Mass air flow sensor, it meassures barometric pressure and air flow.
Check its connection, otherwise replace it.
Callaway SC750 ZL1, DIY 1LE with added OEM 1LE Wheels, DSSV Suspension and 1LE Aero, FEA front control arms, DIY oil cooler, CWA 150 pump, bigger intercooler, Phenolic blower spacer, 82°C thermostat, BMR lockout kit, CTSV Brake Air Deflectors, Smooth idle cam, LS7 lifters, Bronze trunnion bushings. Tuned by JRE
SpeZ is offline   Reply With Quote
Old 05-12-2025, 09:36 AM   #8
veaceonee
It appears I may have it solved. Got one of those MAP Sensor break out harnesses and installed it before the Magnuson MAF harness. Cleared codes. Engine runs better, and no CEL so far (its been 3 days). Thank you for all the help.
