Is this normal on my LT1?
When looking at other engine bays on here and online this part is usually tucked in or not visible besides the tube that runs to it. Unsure what it is and can’t find a diagram that shows what this part is. Just trying to see if this is normal or not! Thank you for any advice/knowledge!
![]() Drives: 2019 Chevrolet Camaro 2SS A10 Join Date: Jul 2019
I assume that you bought your car used, that what you have circled is what appears to be a flex fuel sensor meaning that you can run your car on E85 providing that it was tuned after the sensor was installed.
2019 Camaro 2SS A10 Procharged, Flexfuel, with Stainless Works headers back to Legend series mufflers.
![]() ![]() ![]() ![]() ![]() Drives: '23 1SS Sharkskin A10 Join Date: Sep 2018
Bonus prize
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune l GM Lowering Kit Ported LT2 Intake Manifold l Ported 95mm LT5 TB l BMR Rear Cradle Lockout Kit Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l 480whp/467wtq |
![]() Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
No that's not normal. But if it's flex fuel then you got a cool plus for buying the car. Hopefully it works correctly and is actually tuned for it, if that's how this works? I don't have flex fuel so IDK much about it. Anyone know how exactly the OP would confirm he can dump E into the tank? It has to be tuned for it correct?
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60' 2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60' 1998 Camaro Z28 A4 - Bolt-on 1999 Camaro Z28 A4 - Stock |
![]() Drives: 2023 Camaro 2SS Join Date: Jan 2023
I would find a way to check the tune before I dump any E in it for sure.
23 2SS M6
1/30 1100 3/23 2000 3/31 3000 4/04 3400 TPW 4/17 4/19 3800 4/20 4300 4/22 5000 4/24 6000 |
There is a sending wire that routes from the sensor to a wire bank under the fuse box in the engine. If you are able to confirm that it is pinned into that connector, the install part of it is done. Then you'd have to confirm if your car is tuned and if the sensor has been activated in the tune table.
If your car does not go into 4 cyl mode, you are tuned.
#7 |
Your car has been modified and tuned. Someone performed a rookie flex fuel sensor install.
#8 |
![]() Drives: 2022 1SS Team Joe and Becky Join Date: Apr 2021
You can rest assured that your car has been thoroughly performance tested in the past.
#9 | |
![]() Drives: 2011 GMC Sierra 1500 Join Date: Jun 2022
2023 LT1 Coupe M6 - Black (GBA) on Black (H1T)
Blade spoiler (5ZU), Recaro seats (AQJ), Technology pack (Y3W) LT1 PBC engine built by Shane Parker Current mileage: 372 |
#10 | |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
@OP I would listen to this guy ^ - he knows his shit. Might be worth getting in touch with him and see if anything you have needs to be unf*cked.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
#11 |
Tri-County Camaro SWFL
Yeah that's an ugly install. But it's a flex fuel sensor for E-85
#12 |
![]() ![]() Drives: 2021 2SS 1LE Join Date: Aug 2020
Looks like the previous owner had cable/internet installed and the tech didn't do such a good job (come on, doesn't it look a little like a splitter installed on a co-ax line?
) I wouldn't know what a flex fuel sensor is, but if the car's been tuned by a previous owner, doesn't that mean that the engine is no longer under warranty? |
#13 | |
![]() ![]() ![]() ![]() ![]() Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
Current: 2023 2SS 1LE
Prior: 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
#14 | |
