Old 04-02-2025, 08:19 AM   #1
wbeasley
Drives: Chevy Camaro ZL1 2021
How Thieves are disabling your ZL1 Horns
Folks, Someone or some people tried to steal my convertible 2021 ZL1 the other night. At first, after i saw the top cut, i thought it was just some kids looking for something of value. Then that night i was walking into the house and hit the lock button on my key fob and did not hear the beep.. That caught my eye immediately. I opened the door pressed the horn and nothing. Checked the fuse and it was fine. I could hear the relay clicking under the fuse block in the engine compartment. The next morning i was looking at the schematics were the horn is. There is a horn under each headlight. Low tone horn on drivers side, High tone horn on passenger side. they had reached in through the lower left and right duct pulled down the rubber flaps and had direct access to the horns and simply unplugged them before they started to try and steal my car. I have attached clear photos showing this. I recommend you relocate your horns or place something near the horn that would quickly demotivate an attempted disable of the horns.
Name:  Whole Front.jpg
Name:  Left Front full.jpg
Name:  Left front close.jpg
Last edited by wbeasley; 04-02-2025 at 08:21 AM. Reason: Corrected photo orientation
wbeasley is offline   Reply With Quote
Old 04-03-2025, 06:53 AM   #2
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
Great info. Good detective work.
Also, everyone should get an Igla.
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 04-03-2025, 07:13 AM   #3
dfxrte
Drives: 22 ZL1 M6
great info, and agree with above. I've said it 15x in various anti theft forums lol. never use the fob with igla either
22 m6 zl1. cammed, headers, etc
https://ibb.co/qpWHXZM][img]https://i.ibb.co/NKm0Q46/zl1.jpg
dfxrte is offline   Reply With Quote
Old 04-04-2025, 09:43 AM   #4
Drnick
Drives: 22’ ZL1
Convertibles are impossible to secure,the only security
For them is in your own personal garage!
Drnick is offline   Reply With Quote
Old 08-31-2025, 02:37 AM   #5
Gregoslegos
Gregoslegos's Avatar
Drives: 2016 2SS
This same thing happened to me. They didn’t wind up taking the car, my glass didn’t break thankfully for them to get in but my neighbors cameras caught the person at my front bumper for about a min before he tried to break into the car. I hadn’t tried my lock cus I disabled the automatic beep but when I tried it manually no horn was on.
Gregoslegos is offline   Reply With Quote
Old 09-07-2025, 04:41 PM   #6
TurboC3
TurboC3's Avatar
Drives: 23 ZL1, 08 C6 vert, 70 Skylark GSX
I think, we all should zip tie double sided razor blades to the horn connectors. Problem solved.
TurboC3 is offline   Reply With Quote
Old 09-07-2025, 09:06 PM   #7
clj94104
Drives: Camaro ZL1
Why never use the fob? My installer said it was fine.
clj94104 is offline   Reply With Quote
Old 09-15-2025, 05:28 AM   #8
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
Mods - From JRE, the 125 RWHP Kit; From FI Interchillers, the Stage I Interchiller system, 5mm Supercharger/Head spacer plates, Heater blanket; From BMR Suspensions, Motor mounts, Cradle lockout Bushings; From Misc, Train horn in the Abandoned Heat Exchanger location using the exchanger bracket. From Banks, An I-Dash to read it all...
Bangkok_ZL1 is offline   Reply With Quote
Old 09-15-2025, 11:20 PM   #9
roostere4
Drives: 1987 IROC, 2020 ZL1
It really comes down to the level of security you are looking for. The fob can be secure, but also depending on the situation it is less secure than using the pin code.
For example if you keep the IGLA fob with your regular Key Fob, if you keys are ever stolen then the thief wouldn't even know you have the IGLA installed. The car will just start and run for them just like a vehicle without an IGLA installed.
So while might not be something too worried about, give 2 examples where the key can open you up to theft.
First, god forbid you are ever carjacked the car is gone if you have the fob with the key fob. Also even if you have the anti-carjacking option installed, the care might shutdown on them after they drive away. But having the IGLA key will allow them the opportunity to restart your Camaro and drive it away.
Granted if you keep the IGLA fob separate from your key fob then the above won't necessarily be a problem.
The other situation is if you are using the IGLA fob when dropping your car off for Service. This provides an opportunity for someone to steal the keys and then take the car. Better to set a temp pin, and teach your shop how to use. Then if for some reason the car is stolen, it is without a doubt an inside job.
If you use the pin code yourself, it is easy to train someone else to use. You know the rate to input the keys, and the signs your car makes when it is authorized. In my car I know the indicator lights don't flash everytime auth happens, but the beeps do without doubt. Also when you use the pin all the time, you become familiar with the pin change procedure and can change the pin effortlessly whenever you want. It really doesn't add much additional time before you can drive away, especially if your vehicle is set to allow starts but auth before being put into gear.
Also if really concerned about security, and didn't get these options when you had your IGLA installed, I'd recommend asking your installer enabling these options.
  • Anti-carjacking
  • Key Programming Block (This might be default on the newer firmwares) - IGLA needs to be either at least authorized and/or in Service Mode
  • OBD Block - This prevents anyone(dealer, locksmith, thief, etc) from connecting to computers in the car if the IGLA is not authorized and or in Service Mode
The above are really game changers for security.
Note: I am not entirely positive the minimum mode needed to disable some of the security would ask your installer. But know that Service Mode allows everything as the IGLA is basically disabled.
Hope this is helpful!!
roostere4 is offline   Reply With Quote
6th gen, disable, horns, theft, zl1
