Old 04-01-2025, 01:23 PM   #1
bbraswell918
bbraswell918's Avatar
Ridiculous Pollen - Prevention
I live in NC, and apparently this spring literally has the most pollen ever recorded in the states history. I mean it's ridiculous how much it is.
My main question is whether its worth washing the car every week or two even with the pollen levels this high for next couple months? Should I just do a water rinse off and not worry about actually washing it for the time being? Any products that you guys use that do a great job repelling/rejecting the pollen from sticking or anything?
I would assume yes, to prevent it piling and caking up too much, but would like to hear thoughts.
I do not have a garage for the car so it stays outside for right now (unfortunately)
PS: I do still get a tiny bit of pollen inside the car, even when I don't drive it or open the doors at all. Any good ways to prevent this?
2016 Camaro 2SS A8 || SE 2 inch Longtube Headers | SE Offroad X-Pipe | Corsa Extremes | DSX Flex Fuel Kit | MSD Atomic AirForce Intake Manifold | NW 103mm Throttle Body | Roto-Fab Cold Air Intake | Oil Catch Can | e85 Dyno Tune
bbraswell918 is offline   Reply With Quote
Old 04-01-2025, 09:52 PM   #2
discgolf01
Drives: 2018 ZL1 Convertible M6
I have personally used Swiffer dusters on pollen when I get back into the garage. They seem to be electorstatically charged so you barely have to have it touch the surface (I have ceramic coating and Xpel). 3 minutes later, just throw away the duster and use a new one next time.
But if you don't have a garage, I would probably just let it pile up and rinse it off every few days until pollen season is over, then start washing again. Washing it frquently is just a waste of time unless you need it looking clean for a specific drive.
No help on the inside stuff, cars are not designed to be airtight, so it's just going to be a thing for a while.
discgolf01 is offline   Reply With Quote
Old 04-01-2025, 10:54 PM   #3
beowulf556
Drives: Camaro SS 1LE M6
Is it your daily? If not, a car cover might be your answer. Also to your PS, have you changed the cabin filter recently?
2018 Camaro SS 1LE M6
Stainless Works Headers & X pipe | Redline Axleback | E85 | Rotofab | Soler Ported TB | LT2 Manifold
beowulf556 is offline   Reply With Quote
