Old 03-31-2025, 05:50 PM   #1
Slurpee
Slurpee's Avatar
Drives: 2020 ZL1 A10; Shadow Gray Metallic
New Master Cylinder Won't Go On
I am changing my master cylinder on my ZL1. When removing the old master cylinder, I could not remove the nuts with my hand. Had to use a wrench the whole time.
I cannot for the life of me get the new master cylinder on at all. The springs in the brake booster are all the way forward, and no matter how hard I push, I cannot get the master cylinder far down enough to even start threading the nuts.
Am I missing something?
Slurpee is offline   Reply With Quote
Old 04-16-2025, 02:56 AM   #2
ChadGranger
Drives: hoanda
Use a long screwdriver or screwdriver to gently push the piston back deeper into the booster. Do not use too much force to avoid damaging the seal inside.
ChadGranger is offline   Reply With Quote
Old 04-16-2025, 03:02 AM   #3
ChadGranger
Drives: hoanda
Use a long screwdriver or screwdriver to gently push the piston back deeper into the booster geometry dash lite. Do not use too much force to avoid damaging the seal inside.
Old 04-16-2025, 06:07 AM   #4
ctrlz
I guess he double-posted on this problem, but he figured it out:
https://www.camaro6.com/forums/showt...7#post11479677
