Old 03-29-2025, 09:33 AM   #1
Saberscar223
Saberscar223's Avatar
Drives: 2023 Riverside Blue 2SS
Anyone test if the new BCM update prevents you from making a key with the OBD2 port?
Has anyone who’s gotten the Update tested if you can still make a new key via the OBD2 port? Im hoping this made that process impossible for random thieves on the street.
Saberscar223 is offline   Reply With Quote
Old 03-29-2025, 09:50 AM   #2
TurboC3
TurboC3's Avatar
Drives: 23 ZL1, 08 C6 vert, 70 Skylark GSX
No good news, yet. Going to dig further on Monday. Need to order a new key, to do more testing. FYI, I sub car key programming out. My guy was afraid to remove all keys, before we KNOW he can program a new one. But the PIN code came right up, so he thinks there will be no issue, making a key w/ his $1700 programmer. One thing I did notice with the update, the permissions menu seems to be gone in settings.
TurboC3 is offline   Reply With Quote
Old 03-29-2025, 12:02 PM   #3
Saberscar223
Ooh okay thats not as encouraging as I’d hoped haha hopefully he still wouldn’t be able to. Whats the permissions menu being gone entail?
Old 03-29-2025, 12:13 PM   #4
DeuceCam
Drives: LT1
See post 117 on the other thread regarding the update in this forum. GM claims certified locksmiths using approved tools should still have access.
DeuceCam is offline   Reply With Quote
Old 03-29-2025, 02:25 PM   #5
I never understood that arbitrary stipulation in GM's key programming logic. Why do I have to delete all perfectly working fobs before I try to program a new one?
The only risk this opens up is me, the legit owner unable to complete key programming after clearing all fobs, left with nothing working and a long tow or a mechanic house call... Deleting existing fobs should be optional, and deleting "all but the one currently in the car" should also be supported.
Old 03-29-2025, 04:09 PM   #6
Saberscar223
Also is this a tool that would be easy access? Could just anyone get the same tool as him?
Old 03-30-2025, 10:24 AM   #7
TurboC3
TurboC3's Avatar
Yes unfortunately, it is just a good scan tool w/key programming. So maybe the $300 amazon scan tools don't do it now? But the $2000 tools do? Not much of a security update, if so. I will let y'all know when I receive a key and dig deeper.
As far as the permissions tab, there used to be a menu in settings that allowed apps to receive info from the car. I can't seem to find it anymore?
Old 04-01-2025, 05:56 PM   #8
TurboC3
TurboC3's Avatar
After the update...Bad news. 12min and a programmer= new key. It pulled the pin in 2min then 10min to program...SAD.
Old 04-01-2025, 06:19 PM   #9
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Well, it's better than 30 seconds, I guess... Is yours a super expensive programmer or is it one of the $400 ones on eBay?
Old 04-01-2025, 06:40 PM   #10
Deacon Blues
Drives: 2024 Camaro 1SS M6
Bummer, but thank you for checking.
I suppose if it takes longer, even if inevitable, it might be enough of a deterrent or afford time for intercepting thieves?
Deacon Blues is offline   Reply With Quote
Old 04-01-2025, 07:00 PM   #11
TurboC3
TurboC3's Avatar
We used the expensive programmer. In hindsight we should have: 1-Locked the car w/window down 2-Made the key from outside the car, without opening/unlocking the door 3-Tried the "cheap" programmer first. So now, to do that, gotta buy another key. You can only program keys once. If anyone knows a better way we can test, lemme know.
Old 04-02-2025, 10:59 AM   #12
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
Thanks for your efforts! I think that approach might tell us if the common attack vector has been affected in a meaningful way.
