Tightening loose oil pan bolts
I mentioned on my previous post that my oil pan was leaking, and the dealer says it’s the gasket. A lot of people said the bolts are probably loose. I’m just wondering is it possible to tighten them properly without removing anything components, and if not, what do I have to remove.
My browser lagged out so I accidentally posted a similar thread again. My bad guys
![]() Drives: Chevrolet ZL1 Join Date: Jul 2020
On my 17' ZL1, my shop guy who was a previous GM tech (started his own business) was replacing my oil pump and found that the oil pan bolts were loose. I asked if the pan was off before and he said no. I had an oil leak that I didn't even know about because there was never any other spot on the ground.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
My LT1 needed tightened on the few bolts that are exposed there that you can see on the oli filter side of things on the L side, stopped my leaking. I had 3-4 bolts that were loose. That was all mine needed to stop dripping.
