Old 03-28-2025, 10:24 AM   #1
Slurpee
Slurpee's Avatar
Drives: 2020 ZL1 A10; Shadow Gray Metallic
Front Deflector 10mm Bolts
Anyone have the part number for the 10mm bolts that secure the plastic deflector under the transmission cooler? The replacements I got were a little shorter than OEM and they fell out.
Slurpee is offline   Reply With Quote
Old 03-28-2025, 12:35 PM   #2
11570498
MSRP on this one is $7.10 PER BOLT, no kidding
Old 03-28-2025, 12:36 PM   #3
calypso50kid
Drives: 2018 zle, 03 cobra, 92 mustang lx
sheesh be better to go to the hardware store and match it up before id pay $28+ shipping
Owner and driver of the worlds fastest naturally aspirated drag radial car. Hays Consulting and Performance
4.58@151 BBC powered 585 ci 9000+ rpm
https://youtu.be/wSz2OedlNSI?si=SnPoqreXFQ7NLYX8
2018 ZL1 1LE 416ci LME long block, 2650, reflex port injection, full e85, tick performance tr6060, monster triple disc, DSS drive shaft, g force axles.
calypso50kid is offline   Reply With Quote
Old 03-28-2025, 12:38 PM   #4
BTW here's an alternative, it may fit better than the ones you tried: https://www.amazon.com/dp/B07H8B6BF4
Old 03-29-2025, 10:16 AM   #5
Slurpee
Slurpee's Avatar
Those are the 7mm. I am looking for the silver 10mm ones.
Old 03-31-2025, 06:17 AM   #6
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
10mm sounds kind of big for that function, do you mean a 6mm bolt with a 10mm head? Maybe this?
https://www.amazon.com/Rexka-M6-1-0-...zcF9hdGY&psc=1
Old 03-31-2025, 08:48 AM   #7
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
Believe he's talking about the bigger silver ones which hold on the smaller air deflectors on each side of the big center piece. Please correct me if I'm wrong
Check out my youtube channel
https://www.youtube.com/@evans.educa...ocxUzC1ferqeg8
Full SPL suspension / Ported blower / NW 103mm / Rotofab BG / 2" Headers / Ported heads / Upgraded Valvetrain w/ DOD delete / Custom 38% Cam / C7.R Timing chain / Katech Oil pump / BMR motor mounts and chassis braces / Katech 174* Thermostat / Pierburg Supercharger coolant pump / PLM HX / JMS voltage booster / ATI Damper w/ 8.6 Lower / MM Mild catch can / ADM Resevoir / soon to come...
Rebuilt Engine / XDI +30% injectors / PWR Oil cooler setup / GMS Hood bracket
760 Whp / 700 Wtq E50
Evansa22 is online now   Reply With Quote
Old 03-31-2025, 09:31 AM   #8
Slurpee
Slurpee's Avatar
Yes, those.
