![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
2020-2024 Camaro Software Update???
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
![]() Drives: 2022 ZL1 Join Date: Sep 2024
Just a FYI, There’s thread in the TSB section on this bcm update, and also the transmission update.
2022 ZL1 M6 Coupe
Thanks for pointing that out. It's the top post... I seldom leave the ZL1 sub here !
lol, nor do I, but I stumbled over there somehow, and saw it.
2022 ZL1 M6 Coupe
