Old 03-23-2025, 09:05 PM   #1
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Proper Lift Points?
I know this has likely been asked before but I need clarification.
What are the proper lift points for our cars?
The previous shop who did work on my car pushed the fenders out trying to lift it and I have to have it repaired by a body shop. I don't want that to happen again and I need to go back to the shop for new tires tomorrow.
Need4Camaro is offline   Reply With Quote
Old 03-24-2025, 07:25 AM   #2
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
Here you go. Lift points are outlined in yellow, and these are the pinch welds. I highly recommend metal lift pads that install over the pinch welds, so your shop (or you) can jack directly on them. Otherwise, you would need to use rubber jack pads at a minimum. I got mine off Amazon.
My Camaro Journal
Old 03-24-2025, 08:22 AM   #3
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
^ Exactly!! Highly recommend lift pads
hrpiii is online now   Reply With Quote
Old 03-24-2025, 10:44 AM   #4
Taking my car to a shop is EXACTLY why I put ZL1-Addons jack pads on mine.
https://www.camaro6.com/forums/showp...4&postcount=58
Old 03-24-2025, 11:00 AM   #5
antyslope
Drives: 2016 Chevrolet Camaro 2SS Vert
How about rear Jack stand placement should on a convertible? I’m trying to swap out my diff fluid but I’m not sure where to put my jack stands on the rear. I also have metal lift points on my pinch welds so I can’t put the stands there if I’m lifting from those points.
antyslope is offline   Reply With Quote
Old 03-24-2025, 11:43 AM   #6
Falcontamr
Falcontamr's Avatar
Drives: Chevy Camaro SS
On my convertible, I use the jack points. I have the rubber pads that are molded to fit on a jack stand and slotted for the lift point. I've used them on all four lift points to do tire rotations.
Falcontamr is offline   Reply With Quote
Old 03-24-2025, 12:38 PM   #7
antyslope
Sorry if this might sound stupid, but if you’re lifting from the lift point, how do you get the jack stand on the lift point?
And also, these are similar to the rubber pads I have on my stands. Are these similar to what you have?
https://www.harborfreight.com/pads-f...MaAjJgEALw_wcB
Old 03-24-2025, 01:33 PM   #8
Eric10905
Geezer_loves_Camaros
Drives: 2018 2SS, Black, A8
Even if working on (only) the rear, I lift with the jack from the front lift point until I have the clearance I need at the rear lift point. It's a pretty stiff car so the rear follows up pretty closely.
Eric10905 is offline   Reply With Quote
Old 03-24-2025, 01:46 PM   #9
EliteLT1
EliteLT1's Avatar
Drives: 2022 Camaro LT1
If you're using the jack stand under the pinch weld, try something with this shape instead
https://www.amazon.com/dp/B07KFDM55B...n_title_4&th=1
EliteLT1 is offline   Reply With Quote
Old 03-24-2025, 01:50 PM   #10
antyslope
Thank you very much
Old 03-24-2025, 05:27 PM   #11
Deacon Blues
Drives: 2024 Camaro 1SS M6
Best video on this topic, I've used it to safely lift mine. I have the same jack. https://m.youtube.com/watch?v=NX_Qf9...NhbWFybyBsaWZ0
Deacon Blues is offline   Reply With Quote
Old 03-24-2025, 06:14 PM   #12
Need4Camaro
Do those bolt on or wield on?
Old 03-24-2025, 06:37 PM   #13
Deacon Blues
You can either get bolt on (set screw with loctite) or you can get the magnetic lift pucks that can be removed. I put the permanent ones on but either product is good. I suppose if I had multiple vehicles with pinch welds, the magnetic puck would've been more economical to be used across those cars as well.
Old 03-24-2025, 09:01 PM   #14
2018 Blue 1LE
2018 Blue 1LE's Avatar
Drives: 2018 Hyper Blue Metallic 2SS 1LE 6M
I never got a response from ZL1 Addons to this question.
I noticed that ZL1 permanent ones have a white plastic piece in the bottom and the generic ones do not.
The generic ones appear deeper, too.
Is the actual load point the vertical pinch weld? If yes, then the lifting pad MUST come in contact with that surface and then secure the pads.
If you use the pads that are too deep, then you are relying on the set screw to do the supporting.
Install note, on a 1LE, it seems the side skirt obstructs the front lifting points, especially when trying to turn the set screw.
As for the set screw, I think they made them too short when fully set. Not much thread contact in the pad.
I took mine off this weekend and may have to customize them. They were off Amazon and not ZL! Addons.
2018 Blue 1LE is offline   Reply With Quote
