Old 03-23-2025, 06:19 AM   #1
Yves ZL1
Yves ZL1's Avatar
Drives: Canadian 2019 BLACK ZL1
Oil référence differential
Hi guys,
I’m sure this thread have ever been treated… but it’s complicated for me to look and consult them..
I have two références possible for the oil
This one DEXRON®
LS Gear Oil
75W-90
10-4034
1#88862624
and this one
DEXRON® LS Gear Oil
SAE 75W-90 GL-5
• Contains limited sli friction modifier
AC
10-4034
88862624
So there is this GL5 différence … 🤔🤔🤔
And I ‘m looking for the oil pump…
cause I’m going to do this by myself …
I saw some packs and I think that would be the better choice for me … there is just one thing… I have to order with a girl that accepté to ship it to france …
Thanks guys for yours advices…😃😃😃
Yves ZL1 is offline   Reply With Quote
Old 03-23-2025, 06:20 AM   #2
Yves ZL1
Yves ZL1's Avatar
Précision this is for a regular non modified 2019 zl1 (no Track)
Old 03-23-2025, 06:54 AM   #3
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
the two parts you have listed are exactly the same. The GL5 designation doesn't matter. The 10-4034 or 88862624 will get you the proper gear oil. No additional additives needed.
Old 03-23-2025, 06:57 AM   #4
Yves, since the part numbers on these are the same (ACDelco 10-4034, GM 88862624) and they're the correct ones, I don't think you need to worry about that GL-5 spec designation. It applies to both products, they're the same, but maybe one vendor didn't think it was important enough to display.
EP additives
The main difference between GL-4 and GL-5 gear oils is in the level of extreme-pressure (EP) additives. EP additives effectively protect gears by providing a sacrificial layer on gear surfaces; these additives are essential for protecting gears operating under heavy loads and extreme temperatures. A typical GL-5 gear oil provides about twice as much EP additive in its formulation compared to a GL-4 gear oil.
Where are GL-4 and GL-5 gear oils used?
GL-4 gear oils are typically recommended for spur and helical gears found in manual transmissions and transaxles operating under moderate speeds and loads.
GL-5 gear oils are typically recommended for hypoid gears in automotive axles operating under high-speed, high-load conditions.
(source: https://blog.amsoil.com/the-differen...gl-5-gear-oil/)
Old 03-23-2025, 07:09 AM   #5
Yves ZL1
Yves ZL1's Avatar
Awesome answers guys…. Really thanks for your help…in fact pl5 is better … mireiver on Track … but it’s the same
������ just the last thing … do you know where can I get a bi pack (two quarters) with pump… ?
Old 10-08-2025, 09:52 AM   #6
Yves ZL1
Yves ZL1's Avatar
À got both and I’m going to do it … I just read something …
My model is a canadian one … on the oil I ordered there was the B6862624 réf GL5…
I saw on the manual this nearly the same but it finish by 25 … what do you think ?
Thanks
