![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
drag radials, MT vs Hoosier DR2...
So, after having the rear Weld Solana beadlocks on for a week or so, I'm really happy with how they get and keep traction, it's pretty amazing! But, I'm also SHOCKED, with how bad the vibration in the car is after getting reaching 45mph+. It's literally so bad, I can't see actually taking the car down the drag strip at WOT.
The wheels were first balanced with out the tires, but the car vibration started at around 35mph+. I went back to my tire store, they rebalanced with the tires on, and now the vibration doesn't happen until around 45mph+. I think the vibration might be causing false knock in my data logging? After doing some research, this seems to be a very common problem. But, while doing the research, I also came across many people posting that when they went from the MT ET Street R's to the Hoosier DR2's, the vibration went away. So, before I go throwing more money in to bottomless pit as I call it now. I wanted to know if anyone else has had this same experience, did you live with it (not sure I can, it literally that bad), did you change your tires for different ones, does anyone run Hoosiers with out much noticeable vibration? Thanks
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
I would first look for a shop that can Road Force balance the wheels/tires.
#3 | |
![]() Drives: 2020 Camaro SS 1le Join Date: Nov 2023
I'm from Columbus as well. I'm running ET street R's currently, my vibration is only bad at 85+ when I'm cruising. If I'm wot it feels smooth. I agree with tortilla, a road force balance might be a good first step before you go spendng more money
______________________
2020 1SS 1LE M6 Riverside Blue Metallic Forged Bottom End | KATECH PORTED HEADS | HCI | GPI LT NFC |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
Possible issues, off the top of my mind:
- tire(s) or wheel(s) out-of-round [you'll be able to see that when they're spinning on the machine] - not properly balanced (most likely). rear tires can be static balanced (I've done this with my at-home bubble balancer and they're were good from stop to 145+). of course, computer-machine dynamic balanced is generally better and they can balance them at interstate speeds (and is a must for fronts since you change the rotating "mass" turning this way and that (stability?)). - flat spots on tires if sitting for a duration of time. sometimes takes 4-7 miles of driving to smooth things out (depending on asphalt/ambient temperature) - if you're using spacers and they're slotted versus just round lug bolt holes, could be off center Those are just a few items I could immediately recall. Let us know the verdict!
> 2021 Camaro ZL1 1LE A10 > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily |
#5 | |
They can't do the beadlock bolt torque due to company policy. But, he also looked at the notes on my account and he said something to the effect that each tire had several spots that had like +90lbs of required force (or something like that). So, road force balancing might make it better, but might not. I asked about swapping the MTs for better quality built MT's, he said that's hit or miss, and probably more miss than hit.
#6 | |
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#7 |
![]() Drives: 2018 Camaro ZL1 A10 Join Date: Feb 2022
I am on my 3rd set of MT Street R on my C7. They always vibrate no matter what since they come out of round from MT. I run Hoosier DR2 on my ZL1 and vibration is 70-80% better. Still not as good as regular street tire, but very tolerable and I've driven 100+ miles to the drag strips with them on
For street driving, MT do seem to last longer than Hoosier DR |
#8 |
JSH & ZL14ever THANKS !!
#9 | |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
https://www.harborfreight.com/portab...cer-59140.html
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#10 |
MT's balance for shit...said it a hundred times. You could probably google search and find an old post in 5 minutes of me saying it. Lol
#11 |
Thanks RobZL1 and KingLT1 - Yes I did search and yes found your posts and many others on this issues with the MT's. I probably should have done that before buying the read 17x10 that takes the 205/45/R17. Hoosier doesn't make a tire that size.
Update: So, bessen13 above on this post, happens to be in Columbus, and he really helped me out this evening. He checked then thoroughly, the balance isn't the biggest issue. Road Force balance he got them down to under 30lbs. he issue is more extreme. these tires are a total mess, literally. One tire wobbles/ moves side to side almost 1/2". The other isn't so bad left to right, but, has a huge out of shape area right in one section. The tire store is going to get new MT's and see if they are better tires than the one I currently have. At this point with the tire size I need, I can't really swap the wheels at this point. bessen13 - Thanks again you really helped me out and I can't thank you enough!
#12 |
Update: So, my tire shop (Discount Tire, those guys are awesome) is going to order new MT ET Street R's and continue ordering them until they get (2) that show good on the balancing machine and have low/good numbers on the Road Force balance. If I remember correctly the one tire that moved/wobbled side to side by over 1/2" each direction was way out of balance and had a Road Force of 50, the other one with the high spot (out of round), was almost balanced, but had a Road Force of 101.
bessen13 - Thanks again you are going above and beyond the call of duty !
#13 |
Awesome! Discount Tire is my go to also.
#14 |
Update: So, after several attempts trying different sets of Mikey's - The rears are better, but not great, but balanced really well. But, Road Forced seems higher than desired, 40 on one and 57 on the other, not great. Above 45MPH to 50MPH, I start picking up vibration, nothing major, just enough to know it's there. I don't have any more bounce feeling, like I did before, just vibration. The vibration isn't bad until I get to around 65MPH+, then it feels like a very short length, constant rapid vibration, but, better than before.
I know there are issues with the quality of the MT ET Street R tires. I've research and heard from others as well, the Hoosier's seems much better than the MT ETs. But, Hoosier DR2's don't come in the size MT ETs I have (305/45R17). Hoosier does have a 315/35R17 (not sure about clearance/rub and if it fits). Hoosier makes a 28" 17x10 bias ply, but, I'm not sure that's street legal / DOT. One thing I'm thinking, if the tire isn't exactly centered on the beadlock rim when torqued down. Would that cause the tire, while driving to rotate out of round and cause the kind of issues I'm experiencing? Kind of like what I'm illustrating in the (2) photos. So, I think I'll try to exactly center the tire on the wheel. Basically, let the air out, use something like a Cam Buckle strap to pull the tire together/compress 360°, get it fitting exactly centered on the beadlock rim, install the ring, torque it down, and air up the tire again? Interesting fact: The vibration/bounce was so bad before the two previous times I had the MT ETs on. I was picking up false knock in my data log. I'm pretty confident it was the bad vibration causing that. I data log every time I take the car out and the only knock I've record, ever, was the two pulls I did when I had the MT ET Street R's on. Other than all this, I'm clueless.
