![]() Drives: 2022 Camaro 1ss 1le Join Date: Jan 2022
Alternative breakout harness
I learnt that I’ll need a break out harness for my 1le non amp system. But gen5diy are out of stock. What are other alternatives that will work? Maybe from Metra or pac?
![]() ![]() ![]() ![]() ![]() Drives: Chevrolet SS 1LE Join Date: Oct 2019
Someone here got the PAC harness and it had a miswiring in it, as I recall. The Metra one should be okay, or maybe PAC has their act together by now. You don't need a breakout harness, but it definitely makes things easier, cleaner, and reversible if you ever want to go back to stock.
Matt Miller
2020 SS 1LE |
![]() Drives: 2024 Camaro 1SS Join Date: Mar 2024
https://www.camaro6.com/forums/showthread.php?t=627635
post #5 I used this. Worked perfect. Matt is very knowledgeable and had good info also. |
