Old 03-13-2025, 03:09 AM   #1
Jonathan91
Drives: 2022 Camaro 1ss 1le
Adding amps and sub
I have a 22 1le with no amp in the trunk. I have a 4 channel and an amp for my sub along with a loc. I’ll be adding better speakers on the doors, by the rear seats and up in the dash with some tweeters. How would I go about installing my 4 channel amp? Will I need to locate my in car amp? I’m confused thanks
Jonathan91 is offline   Reply With Quote
Old 03-13-2025, 12:23 PM   #2
bandier
Got mine!
bandier's Avatar
Drives: 2021 LT1 RS - Orange Crush
Do a search here... tons of info.
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
bandier is offline   Reply With Quote
Old 03-14-2025, 08:16 AM   #3
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
There's a super-long thread about the SS 1LE factory system and possible ways to upgrade. I also posted a thread with my upgrade project.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 03-25-2025, 07:43 PM   #4
Jonathan91
Don’t want to start another thread but long story short I hooked up all my speakers amps and connected my lc7. I turned it on and my aftermarket speakers wouldn’t turn on only the dash tweeters so I connected the remote in or out forgot which one to my voice amp and all colors lit up and all my speakers started playing turned the car off. Then when I turned it on again they wouldn’t play again now I’ve thrived everything. Even putting another voice amp and nothing. I think the lc7 burned out?
Old 03-26-2025, 07:03 AM   #5
Msquared
Msquared's Avatar
Unfortunately, I don't know anything about that LC7 LOC. The factory Radio Module has four channels of speaker outputs: two front (that get split between the dash and door speakers) and two rear. They are probably only a few watts each. It seems to me if you wired the two front channel speaker wires or all four front and rear speaker wires to the inputs of the LC7, then it should have what you need. It is supposed to accept up to 400w of input power, so there's no way the stock signals damaged it. My best, uneducated guess is that something is not set up correctly with either the amp or LC7 turn-on signal. I'm not sure how that stuff works, but that would be the place to start troubleshooting. Maybe Audio Control has a tech line that could help you?
Matt Miller
2020 SS 1LE
Old 04-20-2025, 08:03 PM   #6
p47dman
Drives: 2024 Camaro 1SS
I also have 1SS with no amp. I located mine in trunk in foam cutout for inflator. close to battery for direct hookup. Fit like it was made to go there. If one did not know better it looks factory.
p47dman is offline   Reply With Quote
