#1 | |
D3RPZILLA
How-To: Install BMR SB053 Front Adjustable Sway Bar & ELK016 Front End Links
Installing the BMR SB053 Front Adjustable Sway Bar & ELK016 Front End Links on my 2021 Camaro ZL1:
Ran into minor issue where having the BMR end links set to match the OEM end links in length and installing them to the stiffest sway bar position caused clearance issue between the sway bar and control arm. ![]() I shortened the end links and clearance issue was resolved. ![]() I also have swapped out the included poly bushings and cheap metal sway bar mounts with the BMR billet mounts and Delrin bushing (not shown in video, will be in a follow up comparison video). A few photos: ![]() ![]() Billet mounts and Delrin bushings: ![]() ![]() ![]() Quick sway bar chart that I made to compare the BMR front and rear adjustable sway bars with the OEM sway bars on the ZL1: ![]() The chart also shows front/rear bias in relation to the OEM setup. A lot of the info I pulled from posts in this forum like this one, https://www.camaro6.com/forums/showp...7&postcount=99.
Website: z1lla.com | YouTube: sub.z1lla.com | Merch: Shop & Etsy YouTube Playlists: Performance Mods | Show Mods | Other Mods ![]() |
| Tags |
| bmr, end links, front, suspension, sway bar |
