Old 03-09-2025, 08:40 PM   #1
JSH
JSH's Avatar
Drives: '20 ZLE
Coolant Reservoir Level?
I cannot figure out why my upper reservoir loses fluid every time I go on a cruise. It sits overnight, and when I go out the next day, the fluid has dropped. The fluid comes back up some after I loosen the cap, but never to the cold fill line. My shop has replaced the cap and pressure tested the system. WTF?
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 03-10-2025, 01:34 AM   #2
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Check your oil, make sure it does not look foamy or otherwise contaminated... Your coolant should NOT be going down at all... Any whitish smoke out of the exhaust at startup or at high power? The only other thing I can think of is a blown head gasket but the oil should be showing contamination...
Old 03-10-2025, 10:53 AM   #3
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Did you fill the lower reservoir to the correct level? If I remember correctly the top is the overflow, not the main reservoir.
Old 03-10-2025, 03:10 PM   #4
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Altitude may exaggerate the fluid expansion. It does lower the boiling point of the coolant, so presumably it could affect how much it expands as it heats up. Is the lower expansion tank half full as normal when cold?
wakespeak is offline   Reply With Quote
Old 03-10-2025, 03:37 PM   #5
JSH
JSH's Avatar
Drives: '20 ZLE
Oil looks perfect, and it's not using any. I'm filling the top reservoir to the cold fill line. When stone cold, the top reservoir is empty and the bottom reservoir is down an 1/2" or so. When I loosen the cap, the bottom fills up and the top partially fills.
2020 ZL1LE A10.
Old 03-10-2025, 11:17 PM   #6
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
If you have the lower chamber filled to its correct level, and the upper is full, maybe air bubbles in the system? Only reason I can see if you're not losing coolant externally or internally. Didn't you just have the engine looked over? Think I saw that, and if so maybe their's some air still in there. Just my guess
Check out my youtube channel
https://www.youtube.com/@evans.educa...ocxUzC1ferqeg8
Full SPL suspension / Ported blower / NW 103mm / Rotofab BG / 2" Headers / Ported heads / Upgraded Valvetrain w/ DOD delete / Custom 38% Cam / C7.R Timing chain / Katech Oil pump / BMR motor mounts and chassis braces / Katech 174* Thermostat / Pierburg Supercharger coolant pump / PLM HX / JMS voltage booster / ATI Damper w/ 8.6 Lower / MM Mild catch can / ADM Resevoir / soon to come...
Rebuilt Engine / XDI +30% injectors / PWR Oil cooler setup / GMS Hood bracket
760 Whp / 700 Wtq E50
Old 03-11-2025, 08:30 AM   #7
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
JSH, you're low on coolant.
The top tank is part of the pressurized loop and should always be completely full. The bottom tank is the overflow/expansion tank and should be half-full.
Old 03-11-2025, 03:13 PM   #8
JSH
JSH's Avatar
Drives: '20 ZLE
I've owned the car almost 5 years and I've handle this process incorrectly the entire time as has my shop. I'll do all of that this afternoon and see how things look tomorrow morning. Thanks!
2020 ZL1LE A10.
Old 03-11-2025, 03:17 PM   #9
clg82
Drives: 2020 Camaro ZL1
tf?! you have a 1000hp car and don't know how to fill your coolant?!
Old 03-11-2025, 03:27 PM   #10
Odabo
Odabo's Avatar
Drives: 2023 2SS 1LE
In my opinion the manual is somewhat vague in how it explains it. The manual talks about the expansion tank service port but does not point it out. For those who have a strut tower bace, like me, the expansion tank service port is hidden under the strut tower brace.
Thankfully, this forum has so many knowledgable owners who know how to properly maintain these cars and are willing to share their knowledge and experiences. For that, I am grateful.
2023 2SS 1LE Radiant Red, A10, PDR, Black Lugs, ACS Rock Guards, ACS ZL1 1LE Side Skirts
Odabo is offline   Reply With Quote
Old 03-11-2025, 06:21 PM   #11
JSH
JSH's Avatar
Drives: '20 ZLE
Yes, but I'm comforted by the fact that I'm not the only owner who didn't know how to do it properly.
The service port is obvious on mine as it doesn't have a cross brace.
2020 ZL1LE A10.
Old 03-11-2025, 08:02 PM   #12
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
Didn't someone mention this around post 3.........
Old 03-12-2025, 09:18 AM   #13
Gunkk
Gunkk's Avatar
Haha no you're not, which is why we old folks poke our noses in here every so often to help those who don't RTFM
Old 03-12-2025, 12:06 PM   #14
JSH
JSH's Avatar
Drives: '20 ZLE
Yesterday I followed the procedure in the manual, drove the car and parked it. This morning the top reservoir was half full and the bottom reservoir was 3/4 full. The procedure says the bottom tank should be half full in the top tank should be full but I don't see how I'm going to get to that stage
2020 ZL1LE A10.
