Old 03-06-2025, 10:33 AM   #1
Itethai
Itethai's Avatar
Drives: ‘23 SS M6 vert
Not driving enough? Wth
Have a ‘23 SS vert with 2700 miles on it that I got 2 years ago exactly. Starting to play the find the issue of ‘why it doesn’t start after it gets hot’, but starts after about 15 minutes of sitting’ game with my local dealership once again. Foreman now telling me that I don’t drive it enough. Is this guy just a dumbass or is there something to that? In all of my fifty or so years tinkering with cars, Ive never heard something like this.
Thanks in advance for replies.
Itethai is offline   Reply With Quote
Old 03-06-2025, 09:26 PM   #2
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
i have 2300 on my 18 zl1 1le and do not have that issue
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 03-06-2025, 09:28 PM   #3
bishopts
bishopts's Avatar
Drives: 2017 2ss 6mt
seems like a key issue
Old 03-06-2025, 10:05 PM   #4
Instead of listening to that foreman, check out this thread: https://www.camaro6.com/forums/showthread.php?t=586153
Old 03-06-2025, 10:15 PM   #5
JoeCamaro444
JoeCamaro444's Avatar
Drives: 2018 2SS M6 Hot Wheels Camaro
I have approximately 1800 miles on my 2018 Hot Wheels 2SS, and never have any issues like yours. It sounds like they’re lost, and trying to pass the buck on figuring it out for you. Best of luck on this!
2018 2SS M6 Hot Wheels Camaro loaded (Moonroof, Magnetic Ride Control, NPP, etc…)
Previous cars:
2017 1SS Nightfall Gray Metallic w/A8 and NPP
1988 IROC-Z (tons of mods), 1995 Z28, 1998 Z28, 2006 GTO, 2010 Camaro 1SS, 2015 Subaru STI, a couple Acuras and multiple Jeeps.
JoeCamaro444 is offline   Reply With Quote
Old 03-06-2025, 11:10 PM   #6
cgdelena
cgdelena's Avatar
Drives: 2019 2SS
My son had the same problem with his Traverse. Turned out to be a starter with heat problems and the problem was completely solved with a new starter.
cgdelena is offline   Reply With Quote
Old 03-06-2025, 11:22 PM   #7
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
https://www.camaro6.com/forums/showp...&postcount=212
Old 03-06-2025, 11:58 PM   #8
JohnE
Drives: 2016 Camaro SS / 1SS
I own a 2016 SS. I ended up buying the following off amazon and then hooked it up to the water pump bolt:
https://www.amazon.com/dp/B0BGRX8VY9
I bought a longer bolt and a nut and washer and it 100% fixed my issue. Took me about 20 mins to install. Apparently this same issue existed on the gen5 Camaro's as well. I was under the impression that the newer Camaro's didn't have this problem, that it was more common in the early Gen6 V8's.
JohnE is offline   Reply With Quote
Old 03-07-2025, 04:27 AM   #9
Warrior102
USCG Retired (MKC)
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
Follow the links provided it's a well known issue with a $15 fix.
Warrior102 is offline   Reply With Quote
Old 03-07-2025, 09:59 AM   #10
Itethai
Itethai's Avatar
Yep, the dealership is trying to deny its heat soaking issues last year. The only way they would look at the issue is if it could be replicated at the dealership “per GM”. Took there five times and couldn’t replicate , sixth time finally didn’t start at the dealership. They changed the battery after having my car for two days. That’s why I mentioned about having to play their game again.
Old 03-07-2025, 10:04 AM   #11
Itethai
Itethai's Avatar
It’s not a slow crank, all I hear is a relay click under the hood and nothing.
Old 03-07-2025, 11:01 AM   #12
Rnovrit
Drives: 2018 NFG ZL1-1LE
Starter issue like posted already. These cars are notorious for hot start problems. Adding the ground cable will help for sure. In some cases the slow crank over time damages the starter due to excessive amperage draw. My suggestion would be replace the starter and add an additional ground strap/wire from the engine to chassis. Some guys add the wire on the front area of the engine like already described. Others, including myself, added the wire from the bell housing area near the starter to an existing ground stud above and to the passenger side of the transmission under the car.
Rnovrit is offline   Reply With Quote
Old 03-07-2025, 02:28 PM   #13
Abubaca
Abubaca's Avatar
Drives: 2016 SS
With regard to adding an additional ground, I'd always add it in a place that others have already done without issue. I know the Silverado's have issues with certain sensors NOT reading voltage properly when people have added grounds in the wrongs spots. I guess some factory grounds will actually ground THROUGH a sensor. A new ground provides a new path for electricity to flow though. LOTS of people on the truck forums will tell you BETTER grounds not MORE grounds.
Not sure if that's a Camaro thing, BUT....can't hurt to be mindful of that.
Abubaca is offline   Reply With Quote
Old 03-07-2025, 03:55 PM   #14
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
"don’t drive it enough" Sounds like he's just making fun of the situation because of the low miles you have. So yeah, it's stupid.
I didn't realize the newer cars had this issue with the starter. I thought that was the older 6gens. If that was my car, I would be adding a ground wire just like the other dudes have had to do. If that fixes it then great. If not, I would look to see if powermaster makes an LT1 starter.
No starting issues yet (knock on wood) on my 22 with 10-11k miles on it.
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is offline   Reply With Quote
