Old 03-01-2025, 04:20 PM   #1
FastEd
Drives: 2018 ZL1 1LE
Green drop in filter.
Hi everyone, I have ZLE, was going to do an intake but changed my mind. Looking just to do a drop in filter. Not a whole a lot of options for ZL1.Came across Green Filter, never heard of them, seen them or seen anyone using them. Here is the link, is this a good option, anyone shed some light?
https://gbpperformance.ca/en/filtres...yABEgIsafD_BwE
That Camaro Life
2018 Camaro ZL1 1LE
2017 Camaro 1SS - SOLD
2019 Camaro I4 2.0T - SOLD
2024 Mazda CX-50 - Winter beater
2021 Dodge Durango R/T TnG - SOLD
2019 Mazda 3 - SOLD
2013 Dodge Journey R/T - SOLD
1985 Porsche 944 - SOLD
2011 Volkswagen Jetta - SOLD
2000 Honda Prelude - SOLD
2007 Tayota Matrix - SOLD
2004 Mazda Protege - SOLD
2004 Pontiac Vibe - SOLD
2000 Ford Focus - SOLD
FastEd is offline   Reply With Quote
Old 03-01-2025, 05:25 PM   #2
SpeZ
SpeZ's Avatar
Drives: 2019 ZL1 "1LE" | 16 SS | 2017 F30
Using the same.
I heard it's similiar to the K&N drop in filter, just a bit better manufactured.
Callaway used the green filters on their models
Callaway SC750 ZL1, DIY 1LE with added OEM 1LE Wheels, DSSV Suspension and 1LE Aero, FEA front control arms, DIY oil cooler, CWA 150 pump, bigger intercooler, Phenolic blower spacer, 82°C thermostat, BMR lockout kit, CTSV Brake Air Deflectors, Smooth idle cam, LS7 lifters, Bronze trunnion bushings. Tuned by JRE
SpeZ is offline   Reply With Quote
Old 03-01-2025, 06:51 PM   #3
FastEd
Originally Posted by SpeZ View Post
Using the same.
Any issues? I am little hesitant because it is oiled.
That Camaro Life
2018 Camaro ZL1 1LE
2019 Mazda 3 - SOLD
Old 03-02-2025, 08:46 AM   #4
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Should be no issue running an oiled filter. Over the years I have run them(K&N) in two of the Camaros I used to own and no problems. The RotoFab intake in my ZL1 has an oiled filter and it good to go.
Old 03-02-2025, 09:33 AM   #5
SpeZ
SpeZ's Avatar
nop, works without problems.
Meanwhile mine is basically dry, running the same filter since 6 years. Cleaning it with air pressure each year.
Problems with oil usually occur, when you add oil and use too much.
If you buy these filters new, there is just as much oil as needed.
Old 03-03-2025, 09:06 AM   #6
hawk02
Coupe Newbie
hawk02's Avatar
I ran a Green drop-in filter in my previous ZL1 and now run one in my CT5-V Blackwing.
Never had any problems. You probably won’t notice any difference between the paper OEM and the Green.
I did remove the rain/snow blocker on my ZL1 which provides a more direct path for the air to enter the stock air box. Removal doesn’t provide any more boost but it seemed to build boost a little faster which gave my ZL1 a little more grunt in the lower rpms.
https://www.camaro6.com/forums/showp...2&postcount=20
Old 03-03-2025, 10:07 AM   #7
Mark R
Drives: 2018 ZL-1
Check the performance of that filter before you get it. Oiled filters are not great at filtering. The stock filter is best.
https://www.billswebspace.com/AirFilterTest.htm
Old 03-03-2025, 07:28 PM   #8
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Cool
The Green air filter is a great part! On our Project Shocker, the stock airbox managed to supply enough airflow to make 697whp & 715tq with supporting modifications and it also helped keep MATs cooler than my ZLE using the RotoFab which breathes air from under the hood and the fenderwell areas.
Here is a video test comparing the RotoFab to the Stock airbox and Green Filter.
Patriot Motorsports USA is offline   Reply With Quote
Old 03-06-2025, 02:48 AM   #9
PowerDemon
PowerDemon's Avatar
Drives: Camaro ZL1, Golf R
Does it add any more intake noise?
’22 ZL1 Riverside Blue 6MT
’17 Golf R Limestone Grey DSG
PowerDemon is offline   Reply With Quote
