Old 03-01-2025, 10:13 AM   #1
Mike8491
Drives: 2022 ZL1
Pulsing steering wheel vibration
2022 ZL1 coupe with 5200 miles. Pulsing steering wheel vibration between 55 and 60 mph. Pulses are about 1/2 seconds apart. Road force balanced all tires with no change. Vibration only noticeable on newly resurfaced smooth asphalt road. Any thoughts appreciated
Mike8491 is offline   Reply With Quote
Old 03-01-2025, 11:50 AM   #2
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
Low miles so I doubt its a wheel bearing (hub bearing). Not likely brake pad / rotor related given that only experience at specific speed and not under braking condition. Could be tire/wheel weight (one fell off), or lug nut related, but also unlikely given your recent road-force balance.
Since the conditions you experience this under are very specific (newly paved road, and at a specific speed), my guess is you are only seeing this on one particular road and that this may be a by-product of the paving process. Ever drive on a newish road and hear the tires "sing?" It's nothing you can see, but causes a resonance within the tires. Try another (but different) smooth road and see if the vibration is there.
N Camarolina is offline   Reply With Quote
Old 03-01-2025, 12:01 PM   #3
Mike8491
Drives: 2022 ZL1
Thank you for your response. I have noticed the same condition on other stretches of newly asphalt paved roads. I bought the car with 1700 miles. I believe I hear some tier sing on smooth roads as well. Doesn’t pull right or left. Could there be an alignment issue that isn’t revealed by right or left pull?
Old 03-01-2025, 12:34 PM   #4
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
I had the same exact issue on my 2016 Camaro SS. I didn't keep it long after I "think" I fixed it, but I replaced front pads, rotors AND wheel hubs and it finally seemed to fix the issue.
Do you by any chance wash your car/wheels and then immediately pull into the garage (ie not take it around the block after your done washing it). The reason I ask is because I did that and my hubs where so rusty I believe it was keeping the rotors from sitting true on the hub surface thus leading to vibrations on smoothly paved roads.
It might be worth inspecting your front hubs. If they look like they came off the titanic, I would try replacing them. If you can get the rust off, put everything back together and see if it helps. Mine were so rusty you could not get the rust off unless you used a hammer and chisel.
Current: 2023 2SS 1LE
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is online now   Reply With Quote
Old 03-01-2025, 09:36 PM   #5
discgolf01
Drives: 2018 ZL1 Convertible M6
My first guess would be the road itself having something up with it that aligns with your car's design.
The quick and dirty math says that at 60mph your wheel is doing 12 revolutions per second, or 6 per half second.
So if it was something with your hub, rotors, or pads, it should be more machine gun pace as they complete 1 revolution rather than pulse every half second.
Have you tried this same road at significantly lower or higher speeds?
Or have you maintained the exact same speed with cruise control on this same road but over a long stretch to see if the pulsating changes?
discgolf01 is offline   Reply With Quote
