Old 02-26-2025, 12:20 PM   #1
farrk007
Drives: camaro
Basic mod suggestions/opinion
Thanks in advance guys. I'm not looking to do anything crazy. Car does plenty for me stock. After 7 years of ownership I'm getting "used" to that power/handling since I don't use it that much.
I'm taking the car in to replace some sensors and while there I was considering perhaps a lower pulley mod and a tune along with fresh plugs, then I started reading up on pulleys and see there are "percentages" to these pulleys so I thought I'd better get some suggestions before discussions with the shop. Kinda want to have an idea of what I'm talking about so i'm not sold on something I don't want/need.
Thanks again.
1LE /2018/M6
50K Miles
farrk007 is offline   Reply With Quote
Old 02-26-2025, 01:38 PM   #2
dfxrte
Drives: 22 ZL1 M6
no offense but that makes no sense, just use google and type in stage 1 zl1 mods followed by camaro6 and start reading
22 m6 zl1. cammed, headers, etc
https://ibb.co/qpWHXZM][img]https://i.ibb.co/NKm0Q46/zl1.jpg
dfxrte is offline   Reply With Quote
Old 02-26-2025, 01:43 PM   #3
farrk007
Drives: camaro
Wonderful, Thank you...will do that pronto!
Old 02-26-2025, 01:52 PM   #4
Patriot Motorsports USA
Patriot Motorsports USA's Avatar
Drives: 2021 ZLE, C5 Z06 6.0L Procharged
Cool
That'll be more confusing than asking people which oil they recommend!!
I would begin by asking you about your intended usage of the car since it has been this long and you are going in for some maintenance, I can offer suggestions that have proved to make exceptional power. Our "Project Shocker" just laid down 697rwhp & 715tq on an E30 blend with some basic bolt-ons, full OEM exhaust and retained 100% streetability while proving it is very reliable on the road course.
Click this Link to see the full playlist!
Patriot Motorsports USA is offline   Reply With Quote
Old 02-26-2025, 02:32 PM   #5
clg82
Drives: 2020 Camaro ZL1
You can go this route with a cam and magnuson install as well, while still having 100% streetability and road course reliability
Old 02-26-2025, 02:58 PM   #6
dfxrte
Drives: 22 ZL1 M6
he did say he doesn't use it much and just wants some basic mods.
phase 1 is what he needs - headers and and intake is enough with a tune should make 605ish depending on manual vs auto.
if he wants to spin the blower a bit more an upper pulley will suffice.
no need to complicate it - zl1 phase 1 mod build on youtube or the forum and you'll see the parts, sounds, etc.
Old 02-26-2025, 03:39 PM   #7
farrk007
Drives: camaro
To clarify, I typically do my own basic maintenance, have taking it to the dealer a few times, all basic maintenance. Just never did any mods cos I felt it had enough to get out of its own way & just enjoying it "stock" I appreciate you reaching out and will definite watch your yt video. forgot to add....I don't plan on tracking it just street driving.
Old 02-26-2025, 03:42 PM   #8
farrk007
Drives: camaro
Will look into this as well, Thanks.
Old 02-26-2025, 04:29 PM   #9
swisstyphoon
Former GM Technician
swisstyphoon's Avatar
Drives: 2018 ZL1 A10, 06 Silverado Duramax
For a first mod, I’d recommend going with flex fuel and a tune if E85 is available in your area. It’s one of the best bang-for-your-buck upgrades in my opinion. You’ll get more power without having to mess with pulleys.
Also, check out Ryan Cunningham’s video on YouTube about why you shouldn’t pulley your stock LT4. He breaks it down really well. Here’s the link:
https://youtu.be/aMO1y-am_cY?si=_-1fIAME1HMlbjD0
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can.
2006 Silverado Duramax Diesel
MPI Compound Turbo
40% over Injectors
Efi Live DSP5 Tuning
Follow me on Instagram: SwissZL1
swisstyphoon is offline   Reply With Quote
Old 02-26-2025, 04:33 PM   #10
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
If you have e85 access and want to keep it really cheap and simple, I'd say:
Drop-in green filter
Soler TB
Flex sensor
JMS booster
If you are sticking with 93 pump gas, I'd suggest:
Rotofab Big-Gulp Intake
103mm throttle body
Kong X-port with stock pulley size
Headers
Mods being installed-
Old 02-26-2025, 09:22 PM   #11
farrk007
Drives: camaro
Thank you so much for this swisstyphoon, beautiful backdrop for that sexy beast in your avatar!!
Old 02-26-2025, 09:25 PM   #12
farrk007
Drives: camaro
Soler TB
Flex sensor
JMS booster
103mm throttle body
Headers
From my knowledge of good/reliable fuel grades in my area, 93 is about as good as it gets. so, I don't think going e85 would work for me. but I'll look into your other suggestions. Thanks
Old 02-27-2025, 09:06 AM   #13
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - All Bolt On's
Soler TB
Flex sensor
JMS booster
103mm throttle body
Headers
I have a 100mm Solar up for grabs, if you PM me, and make an other! It worked great with my first round of mods!!! You probably want to consider a Roto Fab, or a Roto Fab Big Gulp (I have a big gulp up for grabs as well, the only thing wring with it is the logo got a bit of black paint on it so it doesn't "look" perfect. My build thread is here, I went from 100% stock to 800+ rwhp, with out opening the engine !
https://www.camaro6.com/forums/showthread.php?t=611982
Good luck on your journey, many users here really helped me get to where I'm at today !
2023 ZL1 A10-Stainless Works 2" Long Tubes & Legend NPP Axle Back•GESI UHO 4.5" CATs•RF BigGulp•Kong 103mm & X-Ported Blower•Griptech 2.30" Upper•ATI Super Damper w/9.45" Lower•THPSI Port Injection w/875cc Injectors•FI Interchillers Stage 2•Brisk RR14S Plugs•Granatelli Malevolent Coils•Katech Low Profile Billet Valve Covers•Katech Duel Fuel Pump•MM Wild 1000HP•DSX Flex Fuel Kit•DSX Billet Lid•DMS 2gal Fender Tank•BMR Cradle Lockout•Weld Solana 18x8 Fronts/17x10 Beadlocks MT ET ST R's•Unlocked TCM•E85=785rwhp/691rwtq +21psi | 1/4=10.5005 @134.21 60ft=1.6182, 1/8=6.8373 @106.11
Old 02-27-2025, 12:08 PM   #14
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Farrk, I would start with a RotoFab intake and then decide on other mods. The only mod I have done is the RF Intake and that’s enough for me but it’s your car so do what makes you feel good. Good luck.
