Old 02-25-2025, 05:48 PM   #1
Wy Guy
SS Papa
Wy Guy's Avatar
Drives: 2022 Camaro 2ss
Does this sound like lifter tick?
Hi all,
Can’t tell if this is lifter tick or if I am being paranoid because this is the first oil change where I had to use 5w-30 instead of 0w-40 (Amazon sent me 0w-50 by mistake, but I didn’t find out until I drained the oil & then had to run to the store and buy some 5w-30 in the interim)the sound seems to be coming from passenger side, and is intermittent. Seems like it skips sometimes.
Had the car since new and never put anything other than 0w-40 and did changes religiously at 5k miles.
Car is a 2022 2SS Manual with 36k miles.
Link to video #1: https://youtube.com/shorts/2ZNz2a1N1Nk?feature=share
Link to video #2 : https://youtube.com/shorts/fO6Z1iWcgNg?feature=share
Thanks in advance!
Wy Guy is offline   Reply With Quote
Old 02-25-2025, 11:12 PM   #2
havelegs
havelegs's Avatar
Drives: 24 LT1 M
I think it sounds completely normal.
24 LT1 M6 Sharkskin Metallic
22 Mazda CX-30
havelegs is offline   Reply With Quote
Old 02-26-2025, 12:43 AM   #3
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Yeah, I'm going with normal, my 2020 SS does the same thing, always from the passenger side, comes and goes some times... Always has me paranoid as well but it's been doing it the whole time I've owned it (5 years since new) with no issues and no codes... Always religiously changed the oil (never has had more than 2,500 miles on the oil (most changes were at far less)) and always used Mobil 1 0W-40 ESP Formula and a PF64 filter...
I think you're fine...
Old 02-26-2025, 08:52 AM   #4
Internet audio is never conclusive, but this sounds like high pressure fuel pump tick to me, not out of the ordinary. Mine ticks even louder because I have aftermarket long tube headers, and this is with non-AFM lifters, so they physically can't collapse.
Old 02-26-2025, 09:11 AM   #5
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Sounds normal-ish but questionable. To me it could resemble what is going on in Service bulletin 23-NA-207 but the bulletin says only for the fuel feed pipe in ZL1s.
I have to ask, has anyone with a SS/LT1 ever had this fuel feed pipe issue?
https://static.nhtsa.gov/odi/tsbs/20...50256-0001.pdf
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60'
1998 Camaro Z28 A4 - Bolt-on
1999 Camaro Z28 A4 - Stock
Dynamical is offline   Reply With Quote
Old 03-03-2025, 06:19 PM   #6
nikerret
Drives: 2014 Ford F-350
Why not just use the -50 oil?
2024 Red Hot 2SS 1LE w/BCD, PDR
2014 F-350 Crew Cab Cassis Cab Dually 6.2L w/4.30
2014 Hyundai Elantra GT
1995 Buick Roadmaster Estate
nikerret is offline   Reply With Quote
Old 03-04-2025, 12:14 PM   #7
Big Lou 1le
Big Lou 1le's Avatar
Drives: 2023 1le
Same sound as mine on the rear passenger side of the engine. 2023 with 1250 miles.
Big Lou 1le is offline   Reply With Quote
