Old 02-21-2025, 05:56 PM   #1
SammYyYyY
Drives: 2018 ZL1 1LE
Lower Harmonic. Balancer/Pulley With Cam?
Apologies for the slightly-duplicate post; I posed a similar question on a prior thread but it ended up evolving into discussion of another point.
My car is getting a BTR Stage 2 cam soon. I have all supporting mods figured out at this point other than a lower harmonic dampener/pulley.
Is the stock dampener a reliability hazard at 7k-7.2k RPM? If not, and I do a lower harmonic balancer, is there a mild lower pulley I should do? The car has a stock, unported blower, so I assume the stock pulley size is likely best but I thought I should check.
Thanks all!
SammYyYyY is offline   Reply With Quote
Old 02-21-2025, 08:08 PM   #2
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Hey Sammy... lots of benefits to the ATI damper... I would consider it a no brainer when doing a cam. I suggest starting with an 8.8" lower pulley which is only 10% OD, and will help offset the loss in boost from your head and cam package. Once you are ready for more power... you can easily change lower pulley for more boost.
The ATI damper eliminates dangerous torsional crankshaft vibrations... and does so with 40% less weight then the OEM.
https://www.griffin-motorsports.com/...4-lower-pulley
Old 02-21-2025, 09:32 PM   #3
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Agree 100% on the ATI. Been using one on my stock LT1 crank with well over 1000 HP for going on 6 years…
Joshinator99 is online now   Reply With Quote
Old 02-21-2025, 11:26 PM   #4
SammYyYyY
Gotcha! Consider it done then.
For a road course car with stock heat exchangers, do you think the 10% OD pulley is going to create heat-soak issues? Or do you think it should be alright. I'm open to either option.
Old 02-22-2025, 12:51 AM   #5
PowerDemon
PowerDemon's Avatar
Drives: Camaro ZL1, Golf R
If you wanted to keep the stock boost level, does anyone offer a stock sized dampener?
’22 ZL1 Riverside Blue 6MT
’17 Golf R Limestone Grey DSG
PowerDemon is offline   Reply With Quote
Old 02-22-2025, 01:47 AM   #6
SOCAL.M6.ZLE
Not that I am aware. 8.6" to 8.8" is the smallest I have seen. Keep in mind, thats only a 10%, so a stock car will gain less that 1 pound of boost. A cammed car would likely gain zero, as it will loose boost due to added efficiency.
Old 02-22-2025, 01:52 AM   #7
SOCAL.M6.ZLE
Yikes, I think the OEM HX sucks... and even a stock car would benefit from an upgrade if racing... but depending on your fuel, and climate, you'd want to data log to see if IAT's are an issue.
If you were not already planning to upgrade your HX during your cam swap... I suggest you highly consider.
https://www.griffin-motorsports.com/...heat-exchanger
Old 02-22-2025, 08:23 AM   #8
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2021 zl1 a-10 WildCherry
DSX makes a custom turned stock diameter pulley at a reasonable price, I am running a 8% overdrive on my ATI its what they Chose of my pulley choices at Rater R tuning in San Antonio. I also prior had installed all kinds of stuff like Speed engineering set of intercoolers and a nice screen to protect them..LOL I am running the stage two BTR cam, its got good lope when they tuned it for cold idle, as with any larger cam its harder for the brake vacuum down low so its just a little harder to stop at idle. They recommended a Converter with it but with none out there its still fine, feels like it is a Panther ready to pounce at a stop light. I did go with a 2650 though, and it sounds like the mild whistle of Blowing over a glass bottle when it does whine compared to the 1740, I do have the 1k DSX lid though.... with what I gave them I got 770 HP and 769 TQ on 92 octane form Oregon...Very happy with it.
2021 Wild Cherry ZL1 A10, Sunroof, Data,Red Carbon Interior, Nav, RotoFab Big Gulp , Elite x2ultra, Borla ATAK, Driveshaft shop, BMR susp, Speed covers, intercoolers, ATI , 2650 MAG, DSX lid, 103 NW, TSP Longtubes & cats, LPE, 1le mods, ,LME cover, Katech pump and chain, Trunnions, BTR stage 2, LPE boostapump, Gforce, Speed eng , Granetteli, etc etc
christianchevell is offline   Reply With Quote
Old 02-22-2025, 09:51 AM   #9
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
If you're tracking the car, don't overspin the blower more than about 5% or you're just going to have problems. Regardless of upgrading the heat exchanger, you are still limited to the bricks in the blower itself to transfer heat during track duty. You would really be better off getting the blower ported and doing a very mild 2.45 upper for a 2% over drive. If you can run flex fuel and get to E30, then going to a 2.38 (5%) upper would be perfect.
You would gain a lot of power up top simply by having the blower opened up and a 103mm TB and big intake so that the Cam can breath. The pulley change is to bring the torque in a bit sooner as porting the blower shifts the power to the right.
GM Gen V Calibrator
Megahurtz is online now   Reply With Quote
Old 02-22-2025, 12:51 PM   #10
JSH
JSH's Avatar
Drives: '20 ZLE
I destroyed the alum ATI Super Damper on my previous motor and am using a steel shell damper now.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 02-22-2025, 06:31 PM   #11
SammYyYyY
Fair enough! Yeah, I'm kinda at the limit of my budget unfortunately, so I don't think I'll be able to do the HX right now.
I should clarify that when I say I road course my car, it's nothing competitive. Just 1-2 amateur track days per year, weekend warrior car that I rip in the mountains otherwise.
So to clarify, would you expect a 10% lower with a cam to heat soak any WORSE than a stock cam on a stock pulley? I want to do the harmonic balancer for the reasons you cited, but am not looking to make the car unusable with the stock HX if that makes sense.
Old 02-22-2025, 06:33 PM   #12
SammYyYyY
Could you provide some details on what kind of dampener that is and where I could pick it up if I went that route?
Old 02-23-2025, 06:03 PM   #13
JSH
JSH's Avatar
Drives: '20 ZLE
ATI, see their site
2020 ZL1LE A10.
